Lighter weight log chains -- where to buy?
   / Lighter weight log chains -- where to buy? #61
Our mini choker gets worked again today. The tow machine was not worn out either. :giggle:
   / Lighter weight log chains -- where to buy? #62
One issue I have with cable chokers is that there is usually too much slack [or length] remaining after choking the log and after winching in they will still drag; whereas a chain choker can be shortened up to the log butt and the winch will then lift the log off the ground for easier skidding.
This assumes that you are not skidding very large logs [30 inch +diameter] and are using an arch of some kind.
   / Lighter weight log chains -- where to buy? #63
You can buy them in different lengths.
   / Lighter weight log chains -- where to buy? #64
I don't where you are from but most hard woodstore have some if not any rigging and wire rope specialists like Sling Choker or store like tooltown, Acklands Grainger or princess auto, have chains for sale they cut it to length and buy the hooks separately.
   / Lighter weight log chains -- where to buy? #65
Light weight choker chains work GREAT! Are easy to store and not expensive so we're sticking with them.
   / Lighter weight log chains -- where to buy? #67
I see no sense in buying a bunch of wire rope chokers in different lengths, when I can just use a choker chain, that can easily be used in any of those same lengths, plus it's just so much easier to carry around.
SR
   / Lighter weight log chains -- where to buy? #68
SR
Although I agree with this statement I know that cable chokers have their place for certain applications.
   / Lighter weight log chains -- where to buy? #70
I think using them on the big wood out west is more likely.
sure but not only that, I find cable less prone to slide off the bark when skidding multiple logs, less prone to unhook and easier to slide under heavy logs then chains.
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
