MX6 Changing Blades?
/ MX6 Changing Blades? #1
fatboy99
Kubota MX58 1974 Ford 4000
To loosen and tighten blade nuts on MX6 is it standard loosey left righty tighty? I don’t want to be struggling anymore than I have to. Thanks.
/ MX6 Changing Blades? #2
yes, standard righty tighty. They are tight…IIRC they are torqued to 625 ft lbs. Here is the manual, they have the whole procedure in there. I need to replace mine soon.
  • MX6 Operator Manual.pdf
Thank you! Let the fun begin. Also do you recommend changing out to new bolts?
Thank you! Let the fun begin. Also do you recommend changing out the bolts? For whatever reason manual doesn’t download, hmmm.
/ MX6 Changing Blades? #5
I don’t plan on changing my bolts
