5610 Throttle Issue
   / 5610 Throttle Issue #1
LoneStarLegend
Ford 5610S
Hey there, fellers! Wondering if anyone can tell me the proper way to adjust the tension on the hand throttle on my 5610S. I set it and won't stay set on that RPM and keeps slipping. It's starting to be a little nerve wracking!
   / 5610 Throttle Issue #2
There is normally a "friction disk" that is adjustable to keep vibration from causing the throttle lever to move. They are made out of leather I believe, and they get "shined up" and no longer grip. Don't know how yours works but follow the throttle linkage to the IP.
I appreciate it. I just found the correct parts diagram. Damn things are $87 for 5 of them!!! I don't think so!
   / 5610 Throttle Issue #4
If they are friction discs, go to a leather shop and by some scraps and make your own.
   / 5610 Throttle Issue #5
You don't know you need a new one if you haven't tried to adjust it. Try tightening the nut under the disc a few turns first and see what happens.
Will do, Harry. Appreciate it.
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
2016 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A56138)
2016 VOLVO VNL64T...
Miller CP-302 Mig Welder (A53316)
Miller CP-302 Mig...
2014 Ford Escape (A50324)
2014 Ford Escape...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
Giyi Telescopic Boom (A53316)
Giyi Telescopic...
