5610 Throttle Issue
   / 5610 Throttle Issue #1
LoneStarLegend
Ford 5610S
Hey there, fellers! Wondering if anyone can tell me the proper way to adjust the tension on the hand throttle on my 5610S. I set it and won't stay set on that RPM and keeps slipping. It's starting to be a little nerve wracking!
   / 5610 Throttle Issue #2
There is normally a "friction disk" that is adjustable to keep vibration from causing the throttle lever to move. They are made out of leather I believe, and they get "shined up" and no longer grip. Don't know how yours works but follow the throttle linkage to the IP.
I appreciate it. I just found the correct parts diagram. Damn things are $87 for 5 of them!!! I don't think so!
   / 5610 Throttle Issue #4
If they are friction discs, go to a leather shop and by some scraps and make your own.
   / 5610 Throttle Issue #5
You don't know you need a new one if you haven't tried to adjust it. Try tightening the nut under the disc a few turns first and see what happens.
Will do, Harry. Appreciate it.
(6) New 2x15 E-Track Ratchet Straps (A54865)
(6) New 2x15...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A54865)
2015 Freightliner...
JET GH-1660ZX Lathe (A47477)
JET GH-1660ZX...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
4000 Gallon Fuel Tank (A50775)
4000 Gallon Fuel...
