2610h loader valve fitting type
/ 2610h loader valve fitting type #1
PreacherM
NW Ohio
Branson 2610h
I'm trying to add a 3 spool valve connected to the power beyond on my loader valve. Can anyone tell me what type of fittings are used on this? It has an adapter threaded into the valve outlet, then a 90 degree swivel that appears to be 3/8 or 1/2 inch pipe thread. I want to be able to hook on to the current adapter.
Looks like I'm on my own here......definitely not standard NPT. Looks like BSPP.
/ 2610h loader valve fitting type #3
I missed this thread before. Should indeed be BSPP thread. 1/2" BSPP most likely.
/ 2610h loader valve fitting type #4
I would suggest measure the fittings that are in the valve today. My 2400H had SAE fittings in the valve and 37 degree JIC on the hose ends.
Got the valve mounted in place, now I can measure hoses and order fittings. Is it possible to reverse the end of the ?spool housing? (In the picture below that would make the handle boot point down. ) that would really clean up my install. Screenshot_20220914-202226_Chrome.jpg
Hope you can make sense out of that.
/ 2610h loader valve fitting type #6
Got the valve mounted in place, now I can measure hoses and order fittings. Is it possible to reverse the end of the ?spool housing? (In the picture below that would make the handle boot point down. ) that would really clean up my install. View attachment 762543
Yes. Take the two bolts, rotate 180 degrees and bolt it back on. You don't even need to pull it out completely. Just rotate it.
EDIT: It's either a 4 or 5 MM Allen wrench.
Perfect! I thought that might be the case.
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A61573)
2019 Kenworth T880...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
(1) 74"X49" TAILGATE (A64280)
(1) 74"X49"...
(10) Free Standing 24' Cow Panels w/1 Gate (A64119)
(10) Free Standing...
