Why no Ecoboost in the F250?
   / Why no Ecoboost in the F250? #171
Ford's ecoboost engines are essentially clean sheet designs fully intended for heavy turbocharging, though. They didn't just slap turbos on to a base V6 and hope it would survive. (note, I did just learn they share the same block as the base duratec 3.5L, evidently plenty strong enough with sufficient cooling capacity).
The pistons, connecting rods and crankshaft are pretty stout (approaching diesel-like, if you will). Piston oil squirters, both port and direct fuel injection, and lots lots more tech.
Funny how they have to “build them like a diesel”. :ROFLMAO:
Says a lot about diesels…
   / Why no Ecoboost in the F250? #172
Yokes, I don’t like single axle tractors. They get stuck on wet grass.
My 5500 has 4WD, so I can get out of those situations (most of the time) and it fits in my garage at the end of a hard work day. It’s also very comfortable.
I’d look at a tandem-much better traction and stability. ;)
I like the turning radius and the tire bill of a single axel. They do get stuck pretty bad. My trucks pretty much stay on the road so I can work with that compromise.
   / Why no Ecoboost in the F250? #173
I’m looking at 4900 & 7400 6x6’s and a few 4x4’s.
Just waiting for the right one. Missed on 2 I should have bought….
   / Why no Ecoboost in the F250? #174
I want to sell my dump truck and get a dumpster truck. I could haul equipment on the back of it, I could run 6 ft sides and still load it with small equipment and haul way more brush than my current truck, and having dumpsters in the construction businesses would be nice.
   / Why no Ecoboost in the F250? #175
I’d do a 16-22k dump trailer before a dump truck.
Cheap to buy, cheap to maintain, insure, register.
Tow’s great behind a diesel 4500/5500 ;)
   / Why no Ecoboost in the F250? #176
I have a 16k dump trailer but the dump truck is the only capable tow vehicle I currently have. And I can tow my skid steer and a load in the bed of the truck where with a dump trailer I’d have to make 2 trips to get the same job done.
   / Why no Ecoboost in the F250? #177
Maybe you need a bigger one?
   / Why no Ecoboost in the F250? #178
Nothing complicated here. To get a lot of torque in a reasonable size engine, you need high cylinder pressures. You can get that through compression ratio or boost or a combination of the two. In any case, you then need enough strength in the engine to withstand the pressure.
I wouldn't be surprised to see EcoBoost in Super Duties at some point, since I would guess a lot of them don't tow a large portion of the time.
   / Why no Ecoboost in the F250? #179
Yeah, maybe. I don’t see much use in a superduty with a tiny displacement engine. Just get a 1/2 ton. Would be nice for fuel economy, but not much of a tow rating.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2017 CAT 315F LCR EXCAVATOR (A58216)
2017 CAT 315F LCR...
2006 Toyota 7FGU60 11,250lb Straight Mast Propane Forklift (A55973)
2006 Toyota 7FGU60...
MILWAUKEE SAWZALL W/ CASE (A58374)
MILWAUKEE SAWZALL...
3 PT SPIN SPREADER (A58374)
3 PT SPIN SPREADER...
2019 GALYEAN...
