Air conditioner woes
/ Air conditioner woes #21
What's with the bad coils and 3 months on the slow boat for the part under warranty to arrive?
Carriers from the 90's still on the job...
Newer stuff it's almost 50/50... well not that bad but under warranty coils?
/ Air conditioner woes #24
and therein lies the problem... in 5 years coils on 3 of the newest package units bad and parts furnished at no charge but they first had to be made and then shipped across the Pacific and labor paid to install...
For a non moving part I would not expect to see failures under warranty.
Daikin marketed as direct Carrier replacement... and they refused to acknowledge any query from me the hospital end user...
On the other hand Carrier still running since 1995 and parts readily available but I have never ordered a Carrier Coil so not apples to apples...
Condenser coils are non-moving parts that rarely go bad so consequently they are not stocked by most companies and have to be ordered from the manufacturer.
/ Air conditioner woes #25
"Bad cooling tower fan motor"
My first thoughts was . Damn ! The man's got a chiller at his home :ROFLMAO:
/ Air conditioner woes #27
Cake walk ! :ROFLMAO:
I got a personal use deal from a manufacturer on a 16 SEER two stage variable speed system that kind of gave me an excuse to want to change it out (never had a two stage compressor in my own home). I can also now say from personal experience that a multi stage with variable speed airflow doesn't have the impact on your humidity levels as a dedicated whole house dehumidifier would have (which is another reason why I wanted to try it).
I've got a AC unit down in the basement that hasn't worked the last 3 years, and now that my father has passed (he lived down there) I'm wanting to try a Bosch inverter and dual fuel it with the old Trane gas furnace and see what it does for heat. I think I could justify it because I'm on LP and it ain't cheap. I know old people, no way would I put in a heat pump for my dad for heat when he was used to a boiler for heat up north LOL
/ Air conditioner woes #28
My first guess would be the 90's stuff was made in the USA with good quality controls in place.
My parents had a refrigerator that worked for over 40 years. The reliability of the newer ones doesn't appear very good.
/ Air conditioner woes #29
I really hate to say this, but doing this for as long as I have, being made in the USA has nothing to do with quality control when it comes to HVAC equipment.
Coils from ALL manufacturers have taken a hit since around 2000 IMO. Name the brand, and they all have had some issues with coils over the last 2 decades. The catch phrase used by manufacturers is formicary corrosion;)
/ Air conditioner woes #30
Want a bigger issue? Try having a Mitsubishi ductless unit installed 6 years ago, have a indoor coil leak, need to replace the coil, and then find out that the coil is now obsolete even though it is still under warranty and not available.
Thing is, you can't use a new indoor head (replace the entire head instead of the coil) because it's incompatible with the existing older outdoor unit.
End user will be getting free equipment (indoor and outdoor unit) less labor to change everything out.
/ Air conditioner woes #31
Sorry to hear about your dad. You wrote about him often.
Regards.
/ Air conditioner woes #32
What do you think of this opinion concerning formicary corrosion being due to the phase out of r22 in favor of R410a beginning in 2010? "the air inside your home has changed little over those 35 years, yet only recently have leak issues arisen. The sole common denominator amongst our leaking coils is R-410A refrigerant."
/ Air conditioner woes #33
All my bad coils 410-A... R-22 no issues approaching 30 years.
/ Air conditioner woes #34
R-410a is much higher pressure than r22. Also coils today use thinner gauge pipe. The result is oxidation in the new coils get pin hole leaks much faster.
/ Air conditioner woes #35
As far as my opinion per your question, if anything 410 runs at a higher pressure than 22, but I don't see the refrigerant causing formicary corrosion itself.
Hard to believe, but even 22 coils fail as well.
Do you honestly think manufacturers wanted to go to R410A? Here is the kicker, now manufacturers have to deal with SEER2 rating going into 2023, AND for better or worse, they pushed back the refrigerant change to 2025 instead of next year.
Think about that...The government tells the manufacturers hey, you're switching to 410, and then less than 20 years later, 410A is going to be phased out and right now, it's a game of chicken to see if there is going to be one refrigerant or multiple refrigerants per manufacturers.
My opinion is that the reason why HVAC equipment doesn't "last" like it use to is because it's being over engineered to meet government requirements, which keep going up. More electrical parts you have in equipment, more chances of something failing.
/ Air conditioner woes #36
I suppose most buyers simply buy what's available when their HVAC unit dies, but are there reasons to buy 410a units while they are still available or is that buying into an obsolete refrigerant that's going to be hard to find after the change over in 2025?
/ Air conditioner woes #37
You still should have time to find R410A after 2025, but 2035 may be another story. No different than R22.
It's getting to the point I can see the value in a "dry" unit (unit with no refrigerant in it, you put it in). R22 drop in's are about the same price as R410A pricing now (little higher, but it's like the stock market some months). Buy a new dry unit, pick up a air handler, flush or replace the line set, then pick your drop in. Downside is it won't be rated and you could be rolling the dice with the actual capacity if you actually do a load.
/ Air conditioner woes #38
I’m starting to see propane as refrigerant… the new ice maker is labeled all over flammable refrigerant and learned it is propane.
It been 8 months and no issues so manufacturers are being creative.
It’s like the ice skating rink closed forever because the cost to switch to a modern refrigerant and all that entailed would never pencil out.
/ Air conditioner woes #39
Whatever it is in 2025, it will be LP based, that was pretty much confirmed a couple of years ago (have to remember, couple of years ago, the target date was 2023).
I have the sneaky suspicion that compression fittings will be surging down the road for copper connections for AC units in 2025 LOL
well, it is a cooling tower. It's a tower in the same sense that the world tower can describe a PC case, and it is for cooling. So "cooling tower" is an apt term in spite of not being the term used in the HVAC trade. I could have used "heat exchanger," but that wouldn't have been any more or less correct.
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2004 Lincoln Town Car Limousine Sedan (A61574)
2004 Lincoln Town...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
