Air conditioner woes
/ Air conditioner woes #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
So I called the people who installed them.
My system is over 15 years old. Someone at the home office must have a mandate after 15 years "We gotta Sell 'em a New one~!!"
They sent a tech and a salesman. The tech diagnosed the problem; a Bad cooling tower fan motor.
It had seized. I told 'em after much wrangling that I only wanted to replace the bad motor.
They wanted $1600 for the fan and demanded that they inspect the air handler in the cellar. After peering at it for 30 minutes, they convinced each other that it must be leaking.
Mind you they didn’t take all the cover screws off. They ledt two along the bottom of the panel so they could peep in like there were pit vipers inside (they really did that so I couldn’t see).
So now the cost jumped to 10 Grand.
BUT they were going to save me. YAAAYYYY~!!!!!
They wanted to replace the whole Magilla and it'll only cost me 18 Grand. But it got better because I could rent to own and pay almost $300 a month for ten years.
30-Thousand dollars was what they hoped to wring from me.
THAT WAS THE PLAN BEFORE THEY GOT IN THEIR CARS.
So I ordered an $86 OEM fan on Amazon.
It came today I installed it wired it up and NO JOY~!!!
So I shall replace the capacitor. I ordered one. They say Monday it’ll come.
/ Air conditioner woes #2
The condenser fan motor on my almost 30 year old Amana system siezed up early this summer. Called the local HVAC guy at 9:00AM, said he couldn't make it until 10:30 or so. Got here right on time, took a look at it and had his trainee start removing it. They got it out, and he had one on his truck, pretty old from the looks of the box, but new. Got it installed, checked the pressures and the AC was back on by noon.
Total cost $359.00.
Of course then,I don't live in NJ.
/ Air conditioner woes #3
I just replace my condenser fan and capacitor also. Amazon $175, luckily I had heard it squeal on startup a few days before it went out completely so I ordered one and replaced it when the new one arrived.
/ Air conditioner woes #5
squealed? I'd a thought that had something to do with the belt. Good to know.
/ Air conditioner woes #6
Was the tech. correct ?
Do you even have power to the fan cap. /motor ?
I have always installed a new cap with a new motor.
Is that the problem ? maybe, maybe not
/ Air conditioner woes #7
Condenser Fan Motor went out in ten year old unit...
I'm 800 miles away and tenant not happy.
Call the company that did the original install and when all said and done $1400... ouch is all I could say as I replace them at work and even the larger ones run a couple hundred...
the fan was definitely seized. It didn't spin easily
They did get the compressor to grunt a bit I heard it run for a little bit. But it stopped the moment I reappeared. I don't think they wanted me to hear it. But that made me think I could keep the Capacitor, but maybe they had a cheater in hand.
Anyway, I have one ordered.
/ Air conditioner woes #9
I get all my furnace and home ac parts from Appliance Repair Clinic, pretty local for me but they do Internet sales and have a huge website. Had to replaced the circulating fan on the rental Bryant condenser (locked up like yours) and picked it up at the Appliance repair Clinic place in Wixom, Michigan but I forgot to get the start cap so they sent me one via Fed Ex no charge. Nice folks to deal with and like I said, they have a large internet presence too. When they are on the way out, they do squeak and that tells you it's time to replace.
/ Air conditioner woes #10
It’s direct drive. The squeal was the bushings on startup. Electric motors are amazing sometimes if their under a light load and never stop they can run for years with bad bushings/bearings they interally levitate like a magnetic train. But will not restart once stop.
/ Air conditioner woes #11
My outside the home condenser is also direct drive (circulating fan) mounted vertically in the center of the condenser heat exchanger. If it squeals, it needs replaced or taken apart and the bearings renewed. They are rebuildable btw.
One thing I've learned is you keep the condenser clean by soaking it down with a diluted mixture of Dawn dish soap and let it sit for 30 minutes and hose it out with a garden hose from the top down. A clean evap unit is much more efficient.
/ Air conditioner woes #12
Some condenser coil fins are so thin that they can bend if one isn't really careful.
For the OP, Congrats on standing your ground with the HVAC company. I have replaced motors and capacitors over time. They go bad. Hopefully your unit can be repaired inexpensively.
/ Air conditioner woes #13
Washed the condenser out while I had the top off to replace the fan.
/ Air conditioner woes #14
I do that at least twice a year. Once in ~Spring when the AC season starts (January/February) and in May when it really starts to get hot. :oops:
/ Air conditioner woes #17
Heat Pumps just starting to make inroads in the region of Natural Gas...
Being around commercial HVAC makes me suspect Heat Pumps will never be as trouble free as Gas Furnaces...
I still maintain a handful from the 1920's which makes them 100 years in service... and no electricity needed.
/ Air conditioner woes #18
They probably are not 100% wrong. It most likely is on its last leg. So even if you get it going again I would start budgeting for a replacement sooner than later. On the bright side you will most likely see an energy cost reduction with the new unit.
/ Air conditioner woes #19
Always replace the capacitor with the motor as a capacitor is $10 or less. Always keep a spare capacitor on hand for every fan as they are cheap and they often go at the worst possible time. A spare relay will also keep you from being down long for not much money. A set of gauges and a $25 multi-meter with temp probe and you can diagnose most all your hvac problems with a little youtubing. Of course to be legal go take the refrigerant handling test it is easy and the cost is not bad like $80 per year which you would spend on a tech coming and doing basic start of season checks/cleaning.
/ Air conditioner woes #20
I've been doing HVAC for a long time. If someone told me they had a "Bad cooling tower fan motor" I'd respond by saying "WTF are you talking about Willis":ROFLMAO:
Not all HVAC companies are bad.
That said, if the unit is 15 years old (made in 2007) you got a good run for the year the equipment was made.
I had a outdoor unit with a bad outdoor TXV that was 14 years old, and I did replace the system (outdoor TXV way more labor intensive along with refrigerant over a condenser fan motor).
My other 13 year unit took a crap. It was the capacitor. Replaced it and it's working fine. However, even on my end, when a unit gets over 12 years old, it could be getting time.
FYI, if I had a nickel for every customer that had to replace (and pay labor even though under warranty) for a bad indoor TXV or coil within 10 years of install, I could retire.
Now, on a sidenote, those not familiar with HVAC, at least in my area, some billion dollar hedge fund companies have been buying up HVAC businesses, claiming they are "local family owned" and their prices have skyrocketed. Same thing happened in my area about 20 years ago. They had a 3 or so year old run with the "new business" and sold it. Go figure. I know if a friend called me looking for help and I couldn't provide it, I'd tell him where to stay away from as I think they are smoking dope.
You are however like me... I want 0% and what's your best price. When financed, people never look at the total amount they end up paying with interest, they only see the monthly payment. Go figure...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
2020 John Deere 2633 Disk 29' 3" (A64047)
2020 John Deere...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63118)
2023 New Holland...
