How to Clean inside PTO Shaft
/ How to Clean inside PTO Shaft #1
ShaneG
Murfreesboro, TN
John Deere 3120
I have an old pro shaft on my old BushHog brand 6' rotary cutter. The shaft has become ever increasingly harder to slide in and out due to a build up of grease and dirt. I have the two pieces separated. It is no problem to clean the male portion. What would be a good way to clean inside the female portion of the shaft?
/ How to Clean inside PTO Shaft #3
I used a piece of half inch PVC pipe to push a rag through. I had the roll pin removed at the time which made it really easy to push the rag clear through. I then used diesel as a solvent to finish cleaning it. It was much easier to clean the inner section. I finished cleaning it with acetone then rubbed in some molybdenum disulfide powder instead of greasing it. I followed that with a bit of WD-40 hoping for some corrosion protection.
/ How to Clean inside PTO Shaft #4
Shine a light into female part to see how far the close fit extends. Normally about 4" which is easy to reach with PB Blaster and rag. If it runs deeper just pour a few oz of transmission fluid inside,reassemble and use it until parts slide easily,dump fluid out,reassemble and grease it.
/ How to Clean inside PTO Shaft #5
I would try to spray if possible. Once clean and lubricated, I keep the shaft in my barn ! Had one fuse so tight...no heat / nothing could separate it. Even had it tied to a tree and pulled with tractor. Kind of like trying to get two plastic 5 gallon pails apart, at some point I give up.
You are probably keeping the PTO shaft under cover, I left mine exposed to the weather too long !
/ How to Clean inside PTO Shaft #6
Like roadworthy says, push a rag through it. Or at least to the end and pulll it out agian with a bent wire retiver. I use paint thinner mixed with some acetone to cut tough old grease.
/ How to Clean inside PTO Shaft #7
I use brake clean or engine degreaser, then hit it with some spray lube. This seems to be an every 5 year event for the brush hog and tiller.
/ How to Clean inside PTO Shaft #8
An ounce of prevention is worth a pound of cure. When not on tractor,most pto shafts lay tilted in a position that alows rain to run down male section and enter female section. I recommend attaching a piece of wire or small chain high up on frame to support shaft tilted up so rain runs in opposite direction and can't enter female end. That also keeps coupler out of dirt.
/ How to Clean inside PTO Shaft #9
I think I bought that mower and bad pto shaft from a shady tractor dealer. Dealer advertised a used mower with brand new pto shaft. When I got it home I put mower on tractor and made a couple of rounds cutting grass. When I raised lift the shaft was frozen as you described and damaged bearings,gears and seals inside tractor. The mower had been used on a tractor with far more horsepower than mower was designed for. The female part was worn so bad the male part wedged and froze in place. The scum had installed a new safty shield and painted ends making it look new. $800 in repair and a week down time made me want to go beat the scum to death with the shaft.
/ How to Clean inside PTO Shaft #10
What do you guys use for grease on PTO shafts? I've been just using whatever's in my grease gun, squeezing some out on a popsicle stick or something and smearing it over the shaft. Seems to work, but I'm wondering if it might be a bit too heavy, sometimes the shafts don't slide as easily as I'd like.
Don't want to get too far into the weeds with a "what's the best grease" thread, just wondering if I could do better.
/ How to Clean inside PTO Shaft #11
I simply give it a good spray with white lithium.
/ How to Clean inside PTO Shaft #12
The grooves got messed up in mine once. I tried lubricant and cleaning without success. Finally I took a file and tried to make everything in there smooth. Never saw any particularly high spots, but it did the trick. I was careful not to over do the filing.
/ How to Clean inside PTO Shaft #14
Just go with white lithium in a spray can. The lubrication is only needed for sliding friction. This isn’t a wear part. Using lots of conventional chassis lube may sort of give a good feeling that everything is fully lubed but it’s unnecessary.
Lots of chassis grease on that shaft works great in the summer, becomes problematic in spring and fall, and a nightmare in winter. I have a snowblower for my Kubota L3010 and I’ve launched a lot of creative vocabulary at the PTO shaft while doing winter hookups.
/ How to Clean inside PTO Shaft #15
I use a boiler tube brush. Works like a champ. McMaster Carr I believe.
/ How to Clean inside PTO Shaft #16
I spray the inside heavily with WD40 and slide the tubes back together and back and forth several times. Then pull them apart and wipe off the male side. Then spray again and put it back in and start sliding. Once they slide smoothly, I wipe them down one last time, spray again and leave them apart for storage.
NEVER store them together and spray every time before use, that's been working for many many years without any problems at all.
SR
/ How to Clean inside PTO Shaft #19
Never had one hang up, maybe because all mine are fully shielded but I di clean and lube them (with motorcycle chain lube yearly).
/ How to Clean inside PTO Shaft #20
Once a year I spray brake cleaner thru it, then run a rag thru it soaked in acetone. When dry I then spray WD-40 gel lube inside the female end and coat the male shaft with polyurea grease I use on the rest of the tractor. Brush hog is my only PTO driven implement and only sees about 30 hrs a year of service, but stays on the tractor year round for ballast. If I used it more I’d clean & grease it more often, but for now once annually works for me.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2023 John Deere 2100 Ripper (A63109)
2023 John Deere...
EXECUTIVE SERIES AIR DAM (A62131)
EXECUTIVE SERIES...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
2019 Chevrolet Tahoe 4x4 SUV (A61569)
2019 Chevrolet...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
