How to Clean inside PTO Shaft
   / How to Clean inside PTO Shaft #1
ShaneG
Murfreesboro, TN
John Deere 3120
I have an old pro shaft on my old BushHog brand 6' rotary cutter. The shaft has become ever increasingly harder to slide in and out due to a build up of grease and dirt. I have the two pieces separated. It is no problem to clean the male portion. What would be a good way to clean inside the female portion of the shaft?
   / How to Clean inside PTO Shaft #2
I would get a bucket and soak it in parts cleaner for a couple hours.
I'd advise not to soak the cardan joints/u-joints. Just the female portion of the shaft that you wish to clean. It should break the sludge down.
To clean it out further, use a small piece of rag and a piece of wire and attach it like you were going to clean a gun barrel and slide it in and out.
   / How to Clean inside PTO Shaft #3
I used a piece of half inch PVC pipe to push a rag through. I had the roll pin removed at the time which made it really easy to push the rag clear through. I then used diesel as a solvent to finish cleaning it. It was much easier to clean the inner section. I finished cleaning it with acetone then rubbed in some molybdenum disulfide powder instead of greasing it. I followed that with a bit of WD-40 hoping for some corrosion protection.
   / How to Clean inside PTO Shaft #4
Shine a light into female part to see how far the close fit extends. Normally about 4" which is easy to reach with PB Blaster and rag. If it runs deeper just pour a few oz of transmission fluid inside,reassemble and use it until parts slide easily,dump fluid out,reassemble and grease it.
   / How to Clean inside PTO Shaft #5
I would try to spray if possible. Once clean and lubricated, I keep the shaft in my barn ! Had one fuse so tight...no heat / nothing could separate it. Even had it tied to a tree and pulled with tractor. Kind of like trying to get two plastic 5 gallon pails apart, at some point I give up.
You are probably keeping the PTO shaft under cover, I left mine exposed to the weather too long !
   / How to Clean inside PTO Shaft #6
Like roadworthy says, push a rag through it. Or at least to the end and pulll it out agian with a bent wire retiver. I use paint thinner mixed with some acetone to cut tough old grease.
   / How to Clean inside PTO Shaft #7
I use brake clean or engine degreaser, then hit it with some spray lube. This seems to be an every 5 year event for the brush hog and tiller.
   / How to Clean inside PTO Shaft #8
An ounce of prevention is worth a pound of cure. When not on tractor,most pto shafts lay tilted in a position that alows rain to run down male section and enter female section. I recommend attaching a piece of wire or small chain high up on frame to support shaft tilted up so rain runs in opposite direction and can't enter female end. That also keeps coupler out of dirt.
   / How to Clean inside PTO Shaft #9
I think I bought that mower and bad pto shaft from a shady tractor dealer. Dealer advertised a used mower with brand new pto shaft. When I got it home I put mower on tractor and made a couple of rounds cutting grass. When I raised lift the shaft was frozen as you described and damaged bearings,gears and seals inside tractor. The mower had been used on a tractor with far more horsepower than mower was designed for. The female part was worn so bad the male part wedged and froze in place. The scum had installed a new safty shield and painted ends making it look new. $800 in repair and a week down time made me want to go beat the scum to death with the shaft.
   / How to Clean inside PTO Shaft #10
What do you guys use for grease on PTO shafts? I've been just using whatever's in my grease gun, squeezing some out on a popsicle stick or something and smearing it over the shaft. Seems to work, but I'm wondering if it might be a bit too heavy, sometimes the shafts don't slide as easily as I'd like.
Don't want to get too far into the weeds with a "what's the best grease" thread, just wondering if I could do better.
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
WOODS 1033674 SUBFRAME KIT (A57192)
WOODS 1033674...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
