Tractor Umbrella's
/ Tractor Umbrella's #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all,
My Kubota M5400 has never had a canopy or any other device to protect me from the sun...My ROPS almost hits the top rafters in the shed I park in, so that's the main reason why. However, I have recently seen some pics of umbrella's that can fit below the ROPS. Most of the ones I have seen online have a max 3.5 star rating and state that the brackets holding umbrella are cheap and break at the welds.
Looking to buy one ASAP and would like your feedback on quality ones that wk, AND are simple to remove and reinstall. I shred under a lot of trees, so I'd remove then and reinstall for pasture and other...anything that is a permanent fixture or takes a lot of time to remove and reinstall will not wk.
Thank you very much inadvance for your suggestions and experience.
Best - tstex
/ Tractor Umbrella's #2
Hello to all,
Best - tstex
Try Rhinohide Canopies.
Thanks Chew...I already found the website and sent Chris a note...it looks very well made, easily removed and made in Amercan...no china xxxx for sure...I also like how quickly you can remove and reinstall. It also looks like it's made w really quality products and it supports an American small business owner...
Do you have one ?
/ Tractor Umbrella's #4
Hello to all,
Thank you very much in advance for your suggestions and experience.
Best - tstex
I use a Golf Umbrella. Priced right and just add a side pipe to the ROPS. I can put it up or down in seconds. :) And these things are HUGE for sun protection.
Some people use them for other things.
Just picture this on your ROPS and how much coverage you will be getting. Stay nice and shady. Save money too!
/ Tractor Umbrella's #5
I hope that John Deere still makes and sells their very nice umbrella. It is completely adjustable for tilt, angle, rotation, and height - plus being top quality throughout. It comes with everything, and reasonably priced. And it even folds up when not in use.
We've had the same JD umbrella one on our old JD for decades now.
/ Tractor Umbrella's #7
/ Tractor Umbrella's #8
thank you mav and scotty...appreciate it !!!
Here's my $5 Golf Umbrella. :) The handle fits within the existing bungee cord on the ROPS.
It was a 92F+ day as you can see the reflection on the top of the umbrella.
Thank you guys...the umbrella seems to be a good option, maybe until I find a permanent one....
Do any of you know what umbrella or similar has really good, thick and durable material?
Thanks again !
/ Tractor Umbrella's #10
Home Depot has some 5' golf umbrellas for $8.00. FIRM GRIP 5 ft. Golf Umbrella in All Black 38124 - The Home Depot. It's a pretty decent umbrella. $8 isn't a lot to risk to see how it actually works out for you.
Some here are putting golf cart canopies on their tractors with tubing that allows the canopy to be slid off. I don't know how much one of those canopies weighs or how much trouble it is to get the canopy on/off.
/ Tractor Umbrella's #11
Hello to all,
Best - tstex
I have a Tuff Top on my M9 open station and it folds down as well.
/ Tractor Umbrella's #12
Umbrellas are old timey. I like the simple idea and I like the look on your tractor...
But for mine I went with a permeant solution. All metal. We have 300 sunny days a year.
/ Tractor Umbrella's #13
Have it mainly because I'm hairless on top and I don't need a sunburned head. Tuff Top's are very sturdy and easily folded not that I ever fold mine because I don't. Other tractor has a cab and climate control.
/ Tractor Umbrella's #14
A bit of PVC pipe, elbows, PVC red-glue makes the frame. I've seen both the golf cart canopies and the dumpster lids.
The Golf Cart Canopies are just as pricey as the ones for compact tractors. $300 to $650.
The dumpster lids (new) are about $28 to $100.
And best of all, these have hinges built in. Add to ROPS and you can flip them back when needed or slide the pins off to remove. Fast and simple.
Example below is a 36x58 (3x5)
About $40 for this one.
36" x 58" 6 & 8-Yard Front Load Lid - JC Pacific Trading Co
Dumpster lids are engineered to take a beating. :)
/ Tractor Umbrella's #15
and being black, they soak up the sun's heat like a dry sponge too.
(INOP) 2009 FORD F-250 XLT SUPER DUTY CREW CAB TRU (A62130)
(INOP) 2009 FORD...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
2016 Deere 180G (A60462)
2016 Deere 180G...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2018 F550 Bucket Truck (A63118)
2018 F550 Bucket...
2019 Ford F-650 Cab and Chassis Truck (A61568)
2019 Ford F-650...
