My tractor has the same electric over hydraulic switch for the pto, and I broke the gr5 shear bolt on my 5' RC hitting the switch at near 540 pto rpm. The circlip was installed on the cutter shaft and held the pto shaft in place though, so there was no carnage.
Now when I was hooked up to a 5' round baler I stopped for some reason with about 4' of bale made and had to hit the switch with at probably 300 pto rpm(so the tractor wouldn't stall), and it started the round baler quite smoothly!
I wonder if the internal tractor pto clutch gets sticky from never slipping when starting a small pto load? My tractor also has an automatic pto engagement feature that it will start whenever you lower the 3pt and stop when you raise it, so it must be designed to engage fairly smoothly, but with a small rotary cutter, maybe it never slips at all and sticks after a while?
