TC35 fuel filter problem SOLVED!
/ TC35 fuel filter problem SOLVED! #1
jedjoe
Warren, Connecticut
new holland TC 35A 2004
Hi All,
PLEASE GO TO THE BOTTOM OF THIS THREAD if you are looking for a SOLUTION to fuel levels dropping inside the fuel filter assembly during tractor use. You are, of course, welcome to read the entire thread.
I have been having a persistent problem on my 2004 TC35. When I run the tractor at a persistently higher RPM (such as when using a rotary cutter), the diesel in the filter bowl keeps dropping. If I neglect to check it periodically, I run the risk of the lines being sucked dry and the tractor stalling out (and the later aggravation of having to reprime the injectors). If I loosen the bowl, diesel easily refills.
I've done all of the obvious. Change the filter, blow out the fuel line and return line, drain the tank and ensure there are no blockages or sediment. Also have checked to ensure that the fuel tank cover is venting. Thanks to TBN, I've tracked down a number of threads that describe this same issue. I've drawn the conclusion that my lift pump is probably on it's way out and it's time to replace it. I order a new one from Messick's and it's on the way.
Question: Does anyone out there either have written instructions on how to properly remove the old pump and install the new one? Looking at it on the tractor leaves me with the impression it's probably a pretty simple job, but impressions can deceive and I'd greatly prefer to have the confidence of knowing exactly how to do it correctly. Also, are there any other parts I am going to need beyond the new pump? The hoses all look to be in good shape. The "collective expertise" of TBN members has never let me down. Thanks!
/ TC35 fuel filter problem SOLVED! #2
I guess I don't understand your logic. I thought the fuel routing from the tank went to the filter first, then to the supply pump, and on to the injection pump from there. Maybe I'm wrong on that?
/ TC35 fuel filter problem SOLVED! #3
It’s possible that u may have to “clock it” differently than received..
As u can see in the picture, there is a hash mark..
& u should ask if it came/comes w a mounting oring/gasket..
/ TC35 fuel filter problem SOLVED! #4
Lift pumps are used when the gravity supply to the inlet of injector pump is not achieved. Do you have a suction pick up tube in your tank? of this was commercially done on fuel tank system (I.e , engine generator and such ) then there would be a suction check valve at the pick up line to avoid back siphoning into the tank. I checked it and they do call it "lift Pump". It seems removing 2 bolts with free up the device provide fuel inlet and outlet is removed first. I don't believe from a looks of the tip if it needs to be timed. If I removed it then I would not move and turn engine and put the matching spline in to the housing the same as I found it.
My logic fails me as well. It doesn't make sense unless you consider that if the pump is not keeping up with the demand at the injection pump (as might be the case if I was running at a high throttle), a vacuum could be created between the lift pump and the injection pump. Then an air leak could introduce air into what should otherwise be a closed system.
Honestly, none of the past threads have appeared to actually create a solution that someone posted. It's obviously an issue in that vintage of tractors (TC 30, TC 35, TC 40). Solutions have been suggested (such as poor to no venting through the cap, blockages at the bottom of the tank, etc.) but none of them make sense when you consider the entirety of the symptoms.
The tractor is now 19 years old, and since the lift pump is a rather modest item pricewise to replace, I'm going to replace it and see what happens. I think I've done everything else that could be causing the problem.
/ TC35 fuel filter problem SOLVED! #6
It DOES sound as tho you’ve tried everything else..
Btw.. u don’t have to “time” the lift/supply pump.. it simply bolts on..
It’s operated by a cam lobe and if u feel like there’s to much pressure when you go to put the new one on.. just bump the engine to move the lobe..
/ TC35 fuel filter problem SOLVED! #7
As I see it for the lift pump to be the problem, it has to be trying to pull fuel through the filter faster than fuel can enter. The injection pump demands nothing. It has no vacuum or suction. Those engines survive quite well without supply pumps, just on gravity feed alone.
No matter how I review it, the problem still comes back to fuel supply, not the lift pump. Maybe getting air in through the return line on top of the filter base? I never understood the logic of that either, but what do I know?
/ TC35 fuel filter problem SOLVED! #8
@jedjoe - I have to agree that this seem much more likely to be a fuel supply issue to the filter bowl. Before changing the pump I would double check all the lines you already checked.
We had the exact same problem just 2 months ago on our TC40D, machine would start & run fine at low idle but as soon after idling up the fuel bowl would be half empty. Loosen the fuel filter bowl & it would fill right back up.
On ours - the fuel gravity flowed freely from the tank to the bowl when the filter bowl was removed. The fuel tank cap vented correctly, we actually removed the cap & cover the tank opening with cheese cloth to make sure it wasn't the cause. Finally, removed the return line at the fuel filter housing & from the engine fuel return (they are just tee'ed together), removed the fuel cap & then blew air through the line back to the tank... put it back together... Still have the same issue.
Thought maybe a collapsed hose but they were new less than 2 years ago, so opted to try the return lines again...
This time same as above, removed fuel cap, removed the return line at the fuel filter housing & from the engine fuel return, clamped off the fuel lines & removed them & sent a good amount of air through the return line back to the tank... also blew some air through the fuel filter housing ports... put everything back together & this resolved our issue.
So I would give it one more try prior to putting a pump in...
/ TC35 fuel filter problem SOLVED! #9
Makes more sense than replacing the lift pump.
Thanks to you all, this has been a productive thread. But I am still struggling with understanding why the bowl slowly fills with air (and not fuel). Where is the air coming from? Why, when I crack the seal on the filter bowl, does the bowl immediately refill? To try to better understand this (since NH does seem to supply such diagrams), I drew a diagram of the system as I understand it. Can you all look at the diagram and correct any inaccuracies?
Just for the record, I've check the venting cap (works fine) check for sediment/restrictions in the tank (nothing there), removed and thoroughly cleaned the fuel filter assembly (there were no restrictions of any kind) and tripled checked the on/off valve, replaced the two sections of the fuel return line (the one that comes from the back of the injector pipes and the other one that comes up from the filter assembly, replaced the "t connector" that joins those two lines as they connect to the main return line, blew out (several times) both the fuel line and the return line.
For the life of me, I cannot find a single problem with the fuel system at any point before it reached the lift pump. That's why I am considering changing the lift pump out (even though, you are all right, it's not logical).
I am not a fluid engineer. Consequently, I cannot make any sense of why this problem is occurring given what I have already done. How can it have anything to do with a tank blockage when the problem is immediately "corrected" when the seal is broken on the filter assembly (partially unscrewing the bowl)? The only thing that makes sense is that air is replacing where fuel should be in the bowl. But where does the air come from if the system is providing a positive pressure through the entire flow (see diagram).
/ TC35 fuel filter problem SOLVED! #11
I would be looking at the passages that involve the return line from the filter base leading up to the tee. I've never understood the need for that port. Most all the tractors I see with that type filter base have no such vent or return line involved. It's just fuel into one port, fuel out of another.
That makes sense to me. It seems that the only place for air to enter the bowl would be from that opening. It doesn't make sense to me either. I see the value of having a place for excess fluid/vapors/even air to go after visiting the injectors. It keeps everything moving in a loop from the combustion end of the tractor to the fuel storage area. Why it needs to connect back to the filter assembly doesn't fit.
I can temporarily shut off that one section of the return line (the section running from the filter assembly to the "T connector" with a hemostat (a medical clamp). And then run the system and see what happens. If I lose power after several minutes of mowing, then I'll know that somehow that one link in the system is essential. If, on the other hand, the bowl stays full and I don't lose power, then I may have my answer. Sometimes I wish that the New Holland engineers who design these systems would visit a site like TBN to explain their thinking.
Fortunately, if this fixes the problem, I can return to the pump to Messick's as long as I haven't opened up the packaging.
No matter what, when I do solve this problem I will be sure to post the fix, as it seems I am far from alone in trying to address it.
Okay, so I followed Harry in KY's suggestion and focussed upon the section of the fuel return line that runs from the top of the filter assembly to the "T connector" that joins the hose that runs from the back of the injectors to the main return back to the tank.
I crimped that short line with a pair of hemostats (two of them just to ensure I had no leakage for this experiment).
Result?: Was able to run the tractor at about 2500 rpm (mowing a field edge) for about 45 minutes with no loss of power/performance. In the recent past, that would have caused my filter bowl to nearly empty. This time, I still lost some fuel volume in the bowl, but only a drop of about 1/2 inch.
I guess I must be on the right track. What's still annoying is that for the last 18 years this was never a problem, and this summer it has been. I'm still flummoxed as to where the air is being introduced. It has to be a location in fuel loop that permits air to be pulled in. If it was a place that had positive fuel pressure, I would have a fuel leak, not the introduction of air. Right?
/ TC35 fuel filter problem SOLVED! #14
Attached is a diagram of the fuel system and a description of how air is bled from it.
  • TC35-40-45 fuel flow.pdf
/ TC35 fuel filter problem SOLVED! #15
If I were fighting this, my next move would be to remove the bowl and filter. Remove the problematic return line from the filter base and blow some air into fitting it came off of, mainly to see if it connects to the inlet side of the filter element or the outlet side. That probably makes no difference either way, I'm just curious. Then I think I would swap some hoses around, run the supply from tank to the lift pump inlet and from there to the filter and on to the engine, thus pressurizing the filter. I prefer that to fighting air leaks on the suction side. Have done that many times with no ill effects. If the situation warrants, I will add an inline screen just ahead of the pump. In this case I don't see where that would be needed.
What to do with/about the return line would be based on results of all that. Leaving it intact might result in too much flow and pressure having a free flow back to tank. Then again having the port available might be handy for bleeding air from the filter base if/when needed. That's a judgement call at this point.
/ TC35 fuel filter problem SOLVED! #16
The return fuel from injectors is warm and can help keep a fuel filter from gelling if it is cold enough. That said it seems to dump in the fuel tank where I guess it could keep it warm too.
Ok, so yesterday I had removed the entire filter bowl assembly and cleaned everything thoroughly. There was absolutely nothing obstructing or limiting any one of the three orifices. I did not think to check whether that return orifice was before or after the filter. I believe it was AFTER the filtering but I can't swear to it.
I went back out about 90 minutes ago and took off the return line from the filter bowl assembly. Ran pressurized air through that line AGAIN. Then, reconnected the line after first ensuring that the bowl was full.
I then went out and did another long mow at about 2500 rpm engine speed. This is the rate that always produced the symptom within 15-20 minutes of mowing.
Guess what?? NO LOSS of height in the bowl!! Ran the tractor at that mowing speed for well over an hour and the bowl stayed full!!
What I did differently this time I am at a loss to define. It worked, but darn if I know WHY IT WORKED... The lift pump will likely show up in the next few days, and I have 30 days to return it without anything more than the shipping cost. So...I'll hold on to it for the next couple of weeks as insurance. I know it's almost certainly not the problem, especially since if it WAS the pump the problem couldn't have resolved WITHOUT replacing it. I just don't want to jinx the repair by sending the pump back prematurely. Call me superstitious.
If anyone out there can offer me a decent explanation as to why it worked this time but did not work the previous 4-5 times I'll buy you a pizza...
My relief that it may be fixed is tempered with the need to give it a few weeks of consistently working without incident. But perhaps (knock on wood), I'm done with this problem. I just wish I could tell all future TC owners with the problem the actual fix.
Thanks all
/ TC35 fuel filter problem SOLVED! #18
The earlier post from dlctcg describing an experience with a similar (if not the same) problem, in which it was stated that it was solved by basically removing lines, etc, and thoroughly blowing everything out. Apparently no parts were actually replaced. Sounds pretty similar to what you've done. That tractor has been working since then, now yours is as well. With everything back as originally configured? Kind of leads to the possibility of a minor blockage somewhere on the suction side of the filter that went unnoticed during all the attempts at finding a problem. Who knows?
At least you know it's running again and hopefully you're done with that.
You are right, it was the very same problem. And, interestingly, it was repeating the "fix" (as dlctcg did) that resulted in what appears to be the solution. Now time will tell.
I'd still be interested in any compelling theory that explains how a partial blockage in the return line could result in air entering the bowl
/ TC35 fuel filter problem SOLVED! #20
I wish I could explain it... but glad it worked!!! Maybe it just has something to do with NH TC's in CT.... :rolleyes:
When I was troubleshooting ours I called upon my brother who is head of a vehicle maintenance for a local town... He kept telling me "it is a fuel delivery problem, stop over thinking it. You have a blockage or collapse line somewhere... it is gravity fed".
Funny thing is after re-clearing the lines & it working... I picked up pizza (& a 6 pack) for him & his wife... I guess great minds think alike (besides we have pretty great pizza in CT... lol)
40ft 6 Door Shipping Container (A64194)
40ft 6 Door...
2016 FREIGHTLINER M2 4X2 SA ROLLBACK (A67148)
2016 FREIGHTLINER...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2022 EZ-GO ELITE...
2017 CATERPILLAR 259D SKID STEER (A65053)
2017 CATERPILLAR...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
