Post your Branson at work. Picture thread
/ Post your Branson at work. Picture thread #121
I use this thing for everything!
/ Post your Branson at work. Picture thread #122
Looks like one of your walls fell off of your outhouse!
:eek:
/ Post your Branson at work. Picture thread #123
I used mine yesterday to haul an outdoor wooden swing into the garage so I could refinish it.
Not exactly "taxing", but it was more than I could carry by myself.
Love those forks.
/ Post your Branson at work. Picture thread #127
The quality of your loader is superb, it always impresses me when you post your machines.
Thank you! If I was doing it again, I would stick with my original plan of building the cylinders with 50 mm bore instead of 60 mm. I don't need the ridiculous amount of lifting capacity this thing has but could use a little bit more speed.
/ Post your Branson at work. Picture thread #128
I'm in complete agreement, part of the reason I bought my BB 4035H (3515H) was to save what's left of my back. It doesn't take much to throw it out if I get in the wrong position or overextended.
/ Post your Branson at work. Picture thread #131
Using my dad's old spreader to haul in some rotted horse manure. I'm just putting it on a pile for now. Will eventually get transferred to the garden.
/ Post your Branson at work. Picture thread #132
Just curious how you're going to get it to "pile" instead of "spread"?
That's a nice pic though.
/ Post your Branson at work. Picture thread #133
That is sort of difficult. This spreader actually does a good job of spreading. I ran it about half speed. After 5 loads I used the bucket to push it into a better pile. Id love to just have a spreader without the beaters. It could double as a firewood hauler.
My neighbor has another dozen loads if someone wants it!
/ Post your Branson at work. Picture thread #134
Here's a couple pictures from today,
she's planting corn 4 rows at a time.
And a couple days ago while assembling the new flail mower;
Haven't even used the mower yet, got it assembled and the gear box filled and half the grease fittings lubed some are not taking grease.
Brand new chinneee fitting, I'll pull some of them and replace them to see what happens.
Lou, I wanted to mention that you may want to check the set screws on the roller collars. I just noticed today that I have lost 3 of 4 set screws on mine. I am going to add a little blue lock tight to them when I replace.
/ Post your Branson at work. Picture thread #135
Nice catch. On any project I make that uses pillow blocks, those things always fly out in a matter of a couple minutes. I just build the thing in a way that I don't have to rely on those set screws.
/ Post your Branson at work. Picture thread #136
I hadn't noticed that but the nylocks that secured the roller brackets actual loosened I noticed it and said well I've got just a little bit to do then I'll take care of it. Not my best idea two swatches later the rear roller fell off on one side and pulled the shaft off the other end. Took some work to clean the accumulated grass off the shaft and get the bearing back on the roller and the brackets and roller back on. Ended up removing the pillow blocks mounting the brackets putting the pillow blocks back on the stub shafts and then hanging the bearings and roller back up as a unit.
/ Post your Branson at work. Picture thread #137
Fall is in the air 👍 so I figured time to get some projects done . First one is moving a free standing platform to a better location. At first we were going to disassemble the stand but way to much work !! So without my wife’s approval ha ha and an excited daughter we set out to prove we could do it . Turned out perfect 👍 Sorry if they are sideways. Can’t figure out how to correct them .
/ Post your Branson at work. Picture thread #138
Second project is working on my swamp of a back yard at the cabin . Wife wanted some block around her bird feeder . Turned out good. Next is trying to get some grass to grow . Lots of weed and feed next two or three years 👍
3144 (A63117)
3144 (A63117)
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
