4 way flashers and turn signals
   / 4 way flashers and turn signals #1
bruce havey
mariaville,me
3 fords
2006 JD110TLB- my 4 way flashers light but do not flash and turn signals do not work- wondering if a flasher could be the problem and where it is located. thanks
   / 4 way flashers and turn signals #2
If your recall vehicles made prior to 1986, the flasher=relay is a metal round can under the dash. After 1986 till early 2000, it was a metal narrow rectangle box in the fuse relay box. Bet your machine uses one of those too. Today, vehicles just use the block block 3 leg Omron rely.
Any flasher over 3-pin is for LED arrangement.
Thanks for info- I found out that the flasher is part of the turn signal switch on these JD110TLB- cost $70 to $100 for switch.
   / 4 way flashers and turn signals #4
:oops::cry: ouch. So rather than the old style for under $10, you got to pay big bucks.
   / 4 way flashers and turn signals #5
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A55314)
2006 Heil Tanker...
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
17101 (A55787)
17101 (A55787)
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
