4 way flashers and turn signals
   / 4 way flashers and turn signals #1
bruce havey
mariaville,me
3 fords
2006 JD110TLB- my 4 way flashers light but do not flash and turn signals do not work- wondering if a flasher could be the problem and where it is located. thanks
   / 4 way flashers and turn signals #2
If your recall vehicles made prior to 1986, the flasher=relay is a metal round can under the dash. After 1986 till early 2000, it was a metal narrow rectangle box in the fuse relay box. Bet your machine uses one of those too. Today, vehicles just use the block block 3 leg Omron rely.
Any flasher over 3-pin is for LED arrangement.
Thanks for info- I found out that the flasher is part of the turn signal switch on these JD110TLB- cost $70 to $100 for switch.
   / 4 way flashers and turn signals #4
:oops::cry: ouch. So rather than the old style for under $10, you got to pay big bucks.
   / 4 way flashers and turn signals #5
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
RURAL KING RK25H TRACTOR (A57192)
RURAL KING RK25H...
