Tilt cylinder on Top and Tilt leaking down with use
   / Tilt cylinder on Top and Tilt leaking down with use #31
I would like to add some rear remotes to the Kubota M59. Then maybe professionally made top/n-tilt cylinders. What is a better quality valve assembly? Four remotes with a combination of detent and float. Could that fix a leak down problem? Bush hogging don’t want to be adjusting constantly.
Speced out a few valve assemblies on Surplus Center. Just don’t have experience which valve manufacturer makes a better product for this application.
In the 12 years that I have been selling Bucher valves, not a single leak down issue that I have been made aware of. Bucher valves can be purchased from me, or directly from my supplier. You would need 17 GPM valves for your application.
   / Tilt cylinder on Top and Tilt leaking down with use #32
Thank you for your input Brian. Exactly what I was looking for. You have been very generous with information to many members over the years.
I spec a valve through the site you included. Think it would be wise to go with your expertise through your company in case I need future help. Thank you.
The M59 has a three line hookup for the backhoe. Two supplies from two pumps and a return. Would this be place to tap for remotes?
   / Tilt cylinder on Top and Tilt leaking down with use #33
Hi MtnView,
My Bucher hydraulics have an external leak (under the black plate where the control knobs go), mounted on a Woods BH65. Woods will not supply any information. I'd be very happy to hear from you regarding replacement items.
   / Tilt cylinder on Top and Tilt leaking down with use #34
Hi MtnView,
So you have an external leak. You need to remove the controls so that you can see and isolate exactly where the leak is.
I'm assuming that you have a monoblock valve. Go to this link and the supplier can get you a replacement part or new valve if that is what is required.
   / Tilt cylinder on Top and Tilt leaking down with use #35
thanks much!
   / Tilt cylinder on Top and Tilt leaking down with use #36
I only use the tilt cylinder when I need tilt function.
Even the best of valves and cylinders can creep over the course of a long 8 hour day mowing.
Its so easy to swap back to the turnbuckle....thats what I use when the bushhog is on. When I put the blade or the plow or something that I am adjusting tilt from the seat, it takes like 2 min to throw the cylinder back on
That's my plan as well for now as well. I also throw the turnbuckle on when using my rear blade as it takes up all of the rear hydraulics and has its own tilt.
   / Tilt cylinder on Top and Tilt leaking down with use #38
Well....having a blade that already has tilt.....I guess I'm curious what your intended use of the hydraulic side link was?
I use the box blade a lot more than I use the rear blade and use tilt on that quite a bit. I got the T&T for the top more than the tilt, but it came as a package.
2010 Kaufman Gooseneck Trailer (A59814)
2010 Kaufman...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
12' CONTAINER (A52706)
BOX BLADE (A58214)
BOX BLADE (A58214)
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
