ponytug
Super Member
Sounds like both the sellers had made poor choices in plumbing; either pipes that were too small, or pipes that corroded (becoming smaller), or both. Easy fix, and might be worth exploring, if you like the houses. My view on those sorts of items is that it is worth horse trading the seller on it. Sometimes they have their heart set in a sales number and will do the fix, and other times they don't want the unknown hassle of fixing it, and will settle for less. We looked at another house with "dry rot" on the inspection report. Not really. The dishwasher flooded, and the "dry rot" was hard water deposits on the underside of the floor. The wood was fine. But the sellers thought that they were selling a problem house, as did other buyers.I looked at a house on a well the other day. We passed because of really low water pressure.
Pressure tank was installed at the well. Had good pressure there.
Dawned on me on the way home, that the pressure loss was due to the 100ft plus worth of distance after the pressure tank. Was no telling what size line was used to run from the well to the house either.
Realtor told me that he showed another house we were interested in down the street. Said that house had even worse water pressure.
I wonder if it's a regional thing. But before this place we looked at and the other place down the street. I've always seen the pressure tank either close to the house or inside the house when on a well.
We looked at home once that had a trickle of water from a spring, and was called out as being a problem. I looked at the pipe feeding the main water tank, yup, a trickle. Then again it was corroded galvanized pipe, encrusted with hard water deposits. The whole line back to the spring was half inch galvanized, and every joint was thick with rust and corrosion. My bet was that there wasn't much more than a pencil thickness inside. Easy fix: new poly pipe.
The overflow from the spring was in the tens of gallons per minute category. I am always amazed what folks put up with.
All the best,
Peter
