Blew out another turf tire
   / Blew out another turf tire #11
Fluid AND a mounted hoe for weight? If I had that tractor with the hoe, I would not fill the tires.
   / Blew out another turf tire #12
^^ My Hoe comes off in a few minutes; two pins, three hose connections. Tires are loaded for those times.
   / Blew out another turf tire #13
I picked up a 1725mb a few months ago. I got rimguard in the turf tires. I haven’t taken the backhoe off since I got it.
   / Blew out another turf tire #14
I picked up a 1725mb a few months ago. I got rimguard in the tires. I haven’t taken the backhoe off since I got it.
Yes, that was my reasoning for not needing the loaded tires. Whenever I needed weight on my TC33D, I would just put the tiller on the 3pt.
   / Blew out another turf tire #15
We’ll I blew out a front a little while ago. I had it tubed and it’s been fine. I had a blow out in a rear tire filled with rimguard. I got it to stop with two plugs. I used it most of the day with no problems. At the end of the day it started leaking in another spot. It’s within a couple inches of the plugged area. I think I’m just asking too much if the tires labeled grass master haha. I wish I wouldn’t have let the dealer talk me into turfs after I said I wanted r14s.
Stupid question but on a filled tire how do I try to save the beet juice? If I get this tire tubed can I still use the beet juice? I’m new to this stuff but I’m learning a lot.
Does the tractor sit outside in the sun all the time? RV people have a problem with tires and use covers.
If I switch tires i definitely don’t want to have to do it again so I need them to last. Does anyone know what wheels I would buy if I wanted to get another set? Is there an aftermarket alternative?
   / Blew out another turf tire #19
It stays in a aluminum truck box I use as a poor man’s shed outta the weather.
Is the box ventilated? Exposure to heat for prolonged periods of time is hard on rubber.
It’s vented pretty decently. I just think the 3” minus is too hard on it. Its pretty much a lawn mower tire. I guess the question is do I think a tube will hold up or do I just swap em all out?
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
1997 National RV Tropi-Cal T/A 35FT Class A Motorhome (A55853)
1997 National RV...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
iDrive TDS-2010H...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
