3-Point Hitch Got a FX265 D, problem is the 3point hitch arms do nothing. New to group and looking for help. Already did complete fluid and filter change.
   / Got a FX265 D, problem is the 3point hitch arms do nothing. New to group and looking for help. Already did complete fluid and filter change.
   / Got a FX265 D, problem is the 3point hitch arms do nothing. New to group and looking for help. Already did complete fluid and filter change. #93
Plunger type solenoid valves, typically used in Whirlpool and Maytag washers to control the water mixing and flow functions.
You would need one of the right height of the plunger, right ID for the plunger shaft and 12VDC powered.
Something like this below where you can literally remove the solenoid off the plastic valve body.
Then use the Yanmar plunger inside the washer solenoid for a fit-up.
EXAMPLE:
This is not my original idea. This has already been done on tractors in the eastern EU where parts are harder to find.
Thank you for that input, I’ll check it out.
   / Got a FX265 D, problem is the 3point hitch arms do nothing. New to group and looking for help. Already did complete fluid and filter change. #96
I was going to try to look up by part number but
don't see one so no help here
willy
willy
Try part 198361-46260. Thanks
Kubota RTV500 (A47384)
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
Killbros 260 Seed Conveyor (A57024)
Killbros 260 Seed...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
2009 Ford F750 Reel Loader Truck (A52377)
2009 Ford F750...
