Sportsman762
- Joined
- Mar 28, 2008
- Messages
- 1,109
So I have a unique problem with a hydraulic valve that I have never seen before. Helping a friend with a Kubota M108S and a LA1403 loader that he recently bought. The tractor has open center hydraulics. When he bought the tractor the bucket was hooked up backwards. So when you moved the joystick to the right it would curl and the left it would dump. To remedy the backwards bucket I switched the lines at the quick disconnect on the loader. The bucket would dump no matter which way you moved the joystick. Move joystick to right and it would dump, move to the left and it would dump. If you set the bucket on the ground it would lift the front of the tractor when you moved to the right, but when you moved to the left it would not quite have the power to lift the front of the tractor. It has less dumping power in the position that it should be curling (left) but seems to have full power when in what should be the dump position (right). The hydraulics for the arm works just fine. I replaced the quick disconnects coupler and nipple and still have the same issue. When I loosen the lines going to the valve the one port gets more flow regardless of which way the joystick was moved.
I cannot switch the arms and the bucket as the bucket has ½” body QD and the boom has ¾” body QD. If I switch the bucket lines so that they are backwards the bucket works just fine but moving the joystick to the right it would curl and the left it would dump and this drives everyone crazy and it is apparent that there is some issue with the loader.
The valve is a Husco 5000 series sectional valve and is factory from Kubota. The valve and loader are not self leveling. The fluid is full and in good shape. When the joystick is moved the spool moves an appropriate amount in the correct directions. There are no check valves, flow restrictors or anything of that sort on the lines. I think that the bucket section on the valve has something wrong with it, however I would like to diagnose before I tear into the valve.
The tractor is 2 hours away but I should be able to test any hypothesis this weekend. Any clue on what could cause the bucket to have pressure to the butt end of the cylinder whenever the spool is actuated regardless of direction.
Sorry for the long write up. However this is a unique problem that I have been unable to find an answer to in this or any other forum. Thanks for the help.
