GeneV
Elite Member
Amsoil synthetic in mine.
			After all this you’re asking us what fluid to use? You need to check with your MF dealer or your Owners Manual for the correct specs. Once you know that you can shop around if you want to. You’ve already messed up the first time, no need to mess up again… However, I’m thinking that you installed hydraulic fluid in your HST tractor, when you should have installed Tractor Transmission/Hydraulic fluid? Let us know…Mowed with old fluid back in tractor for 3 hrs. this weekend worked just fine so it looks like fluid is the problem guess time will tell.
Question what fluid you guys running in your MF tractors I will have to change it sometime.
There's only the one: AMSOIL Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30Help the man out by saying what exactly you have in your tractor (same tractor?), not just oil brand….
So using the manufacturer recommended fluid, and all the MF dealer can do is tell you to run it at lower rpms?Permatran 821XL SEMI SYNTHETIC
The old didn,t say semi synthetic on can
