cdaigle430
to me. it looks like you have some air in your sump which is giving you a misleading level in the glass level indicator.   How many quarts did you add?  I would try removing at least a half a quart...then purge the air by raising and lowering the loader and curling the bucket 10 times, same with the BH if its on.  Check the level again...remove more if necessary.
