Repair Common Kioti Mechanical Injection Pump Failure
   / Repair Common Kioti Mechanical Injection Pump Failure #31
I ran a line from a gas can to where the stock tank connects to the supply pump, so it still goes through the filter.
   / Repair Common Kioti Mechanical Injection Pump Failure #32
So all u did was eliminate the TANK..
U still have the supply pump and filter head..
If it’s the filter head that has the thumb lever that moves up and down to stop the flow..
They have been known to vibrate down to the shut off position from vibration.
And the supply pump can get weak while running also..
   / Repair Common Kioti Mechanical Injection Pump Failure #33
Thank you, I'll look for that and see what I can find.
   / Repair Common Kioti Mechanical Injection Pump Failure #34
We had that on our Kubota BX, it would idle, but not run full out. The lift pump (if electric like the BX) can stop working completely or stop working once it warms up.
Right after it shuts off, remove the rubber fuel line going into the injector pump, stick it into a bucket, turn the key to "on" and see how much fuel comes out.
There should be a good flow, if not it's the lift pump.
Aaron Z
   / Repair Common Kioti Mechanical Injection Pump Failure #35
We had that on our Kubota BX, it would idle, but not run full out. The lift pump can stop working completely or stop working once it warms up.
Aaron Z
It's actually called a lift pump and they are easy to replace. On the side of the block held on with 4 small bolts. Never had one fail but there is always a first time. Some are electric 12 volt some are mechanical and work off the cam shaft. The 12 volt ones will be in the fuel line somewhere between the tank and the primary filter.
   / Repair Common Kioti Mechanical Injection Pump Failure #36
Ah, I was thinking that they were all electric. Updated my post to reflect this, I would think mechanical one would be less likely to fail than an electric one and could likely be rebuilt with a new diaphragm.
Aaron Z
   / Repair Common Kioti Mechanical Injection Pump Failure #37
Aaron Z
The mechanical ones are pretty cheap actually. They work just like a mechanical fuel pump on a lawnmower engine. Arm actuated by the camshaft that compresses a diaphragm through a one way valve.
   / Repair Common Kioti Mechanical Injection Pump Failure #38
Hi folks, I am having the same issue with my CK30, I have new gears coming but what I didn't see here was the placement or orientation of the gear to the control rack. I can't see any marks on the gears but I do see the lines on the rack. Any help would be appreciated. Thanks to all for the above posts, they are a great help.
Your new gears should have those lines that align with the rack lines when all plungers are synchronized at about 50% power. My old gears had no lines but the new ones did.
   / Repair Common Kioti Mechanical Injection Pump Failure #40
CORRECT.. depending on what and where u ordered them, they SHOULD have a dot on a gear tooth..
Good luck
1999 Case 602B Vibromax Sheeps Foot Roller (A59213)
1999 Case 602B...
2005 John Deere 200C LC Excavator (A59213)
2005 John Deere...
1995 Advance Mixer CM3A6811 11 Yard Tri-Axle Concrete Mixer Truck (A56858)
1995 Advance Mixer...
2846 (A58376)
2846 (A58376)
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2000 Caterpillar 3412 625kVA 3-Phase Diesel Generator (A56857)
2000 Caterpillar...
