Lifting Limit
/ Lifting Limit #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
Kubota MX
Could only get stump I dug out about 3 inches off ground
Several more to go
/ Lifting Limit #3
Be careful. When you do that it puts a great deal of stress on your front wheel bearings.
/ Lifting Limit #4
That should be enough to get it wherever it needs to go.
/ Lifting Limit #5
Try curling it back first. It may shift the midpoint of the weight back just far enough so you can carry it higher.
/ Lifting Limit #6
Might try to scrape as much dirt as possible from the root ball with your tines to lighten the stump weight. Can't tell, but it looks like what might be heavy wet clay?
My MX 6000 lifts what appears to be larger stumps, but I try to get as much dirt as possible off the stump and back into the hole before lifting, and I leave them to dry out if I encounter heavy wet dirt in the root ball.
Do you have the standard LA-1065A loader?
Also, how much does your grapple weigh? Greater the tare weight of the grapple > less the available load weight.
As someone mentioned above, I generally run 1800 to 2000 RPMs when using my EA 60" grapple which EA says weighs ~400#.
I don't have an actual photo of lifting this stump after limbing the tree...but we did. And it is similar in size of many stumps picked up and stacked on top of my brush piles with the MX.
/ Lifting Limit #7
Crank the engine revs
Most likely it went into hydraulic bypass and like Hay Dude said, it's very hard on the front wheel bearings. I move round bales around all the time but that's not even close to capacity with my loader and I'm still careful when moving and never in FWA either.
/ Lifting Limit #8
Quite honestly stump does not look that big..... Probably need to up RPM to get more hydraulic power...
Do you have rear ballast?....
If you have the LA 1065 loader you should have about 1691 pounds lift ...
/ Lifting Limit #9
Wrap a chain around it and drag it with the rear draw bar.
/ Lifting Limit #10
Push the stumps out of the way and let it rain on them a year. That's why I love a big ole Trac hoe. Pick them up about 20' and drop a few times, dirt falls off, burn better. Sometimes we dig a pit and burn them in the pit. I've moved stumps a lot bigger than that with a 100 HP skid steer. 5'-6' diameter stumps, tree diameter, stump was about 12' diameter, roots and all. It looks like you are doing too much with too little. Tie a chain around stump and drag it off and away. I wouldn't risk a broke front axle or a sheared pinion.
/ Lifting Limit #11
Is that a SGC1560 grapple? If so that thing is a beast at 820#(100# more if its a 72" grapple). So that is costing you some capacity, because a ~400# grapple is more than enough for a MX.
That said....I agree a little curl back would help, then lift
/ Lifting Limit #12
Actually if you understand the specs, the 1600# is to max height.
At ground level.....3100# at 500mm is the spec (the breakout force). And to a midpoint....bout 5' high.....the lift capacity should be somewhere in between. Somewhere around 2300-2400#.
But having a grapple that is ~400-500# heavier than the standard bucket hurts the net capacity
/ Lifting Limit #13
That is why I quoted the 1600 pounds, figured it was limits was able to lift, and doubt stump is that heavy...
/ Lifting Limit #14
A fresh stump with dirt embedded in the rootball is surprisingly heavy. If it doesn't want to budge, your tractor is telling you to back off.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61572)
2025 Wolverine...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2018 Isuzu FTR Landscape Dump Truck (A61573)
2018 Isuzu FTR...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
20ft trailer (A61569)
