2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,526
I have a set of 5x5 scaffold that I bought used.
The Northern Tool set doesn't look that terribly heavy. It's manageable working with it it piece by piece to assemble. All of it together will be heavy to transport and store.
Make certain that you don't ever let the X braces close on your fingers while putting the scaffolds up or taking them down. You could lose some fingers.
If you have a long wall to work on, you could support an aluminum walkboard between two sets of scaffolding...but it can't be allowed to slip and you have to watch yourself not to fall off. You need to assess whether you would be better off using all scaffold or whether adding a walkboard makes sense in your situation.
If you are going to work from the scafford, you could use 2x10 or 2x12 PT for a deck. This is an affordable option for scaffold that will be left exposed for a longer period, and the PT is easy to store.
You want to make sure that whatever you use for a work surface can't slide off the scaffold.
On uneven terrain, having some screw jacks made for scaffolding legs would be pretty useful to get it level. Like everything else, they won't be cheap.
The base has to be solid and level. Once you get it all assembled, it's going to be so heavy that it will be hard to make adjustments later. The pipe legs of the scaffolding have to rest on 2x material or something solid so they don't slip into the ground. You also need to be sure the scaffold leg can't slide off the support material.
You need to position the scaffold close enough to the wall you are working on to be able to do your work, but not so close that it interferes with your access to the work.
Years ago, we were building some habitat houses on sloped lots. There was another group who had a pretty good head start on their house, but they were using ladders. Our group started after them, but put up scaffold. We got done first because it was more efficient than climbing up and down ladders all day to install the siding. We had enough workers that it wasn't that much of a deal to put up the scaffolding.
The scaffolding will take you longer to put up, but once it's up, then you will have a stable place for working, and it will make the job easier overall than climbing up and down ladders a zillion times.
As for the cost, scaffolding prices just seem to go up. You could resell it, but you probably won't if you expect to have to do this kind of work again in the future.
