What causes this pine tree problem?
/ What causes this pine tree problem? #61
Those insect trails are probably made by the pine sawyer beetle. I see those frass markings often. If you rip off more bark, they could still be at work just under cover.
The tree would have been stressed by some other cause before they came in to feed. I cannot see any evidence indicating the original cause of distress but I like the ideas mentioned here about looking for similar damage in other trees, inspected the sawn wood and getting your county forester in to inspect.
Thanks for the link! It is helpful to have pictures & info like that. By any chance do you know if these beetles have a strange odour when you squash them??? I have bugs that look like this in two different areas- near the front and back doors of my shop …AND some dying pines within 15 feet of both areas. I will get some pics of the bark in the daylight tomorrow. I have to say…I love trees…and never cut them down…and then I put a pool in two years ago.
I thought the pines were far enough away that they wouldn’t be a problem. Wrong.
They wreak havoc on the skimmer & filter, have destroyed my eavestroughs, COVER my 50’x 25’ deck - getting caught between boards and requiring pressure-washing, and basically do nothing but make hours and hours of extra work for me…that I do NOT need! 😊 So I decided a month ago (while cleaning off the deck yet AGAIN) that they are GOING. (My gasification boiler will give them a warm welcome!! 🤣)
My chainsaw trigger finger is getting itchy! Hahaha…but I’m going to wait for some assistance though…because 40’ trees on my shop roof is something else I do NOT need!!! 😊 If you happen to have any links showing the other beetles being discussed I’d appreciate if you could post them! Also…I put a Russian Black currant bush in a few years ago, about 100’ away from the pines. I was recently told that this shrub/bush carries some kind of disease that affects pine trees. Know anything about that? Thanks for any info you have! Patti 😊
/ What causes this pine tree problem? #63
I listen for woodpeckers. If I hear them I know that a tree has some sort of bug infection. A few years ago I had the tree guys three doors down cleaning up a yard come over and drop a three trunk pine tree that dropped needles. I cut up what was on the ground. Green wood is the surefire indication that the tree had pine beetles. Another tree had all the signs last year. Sap tracks and dead pine needles beyond regular seasonal pine needle shedding. Odd that only half the single trunk pine died. I finally got around to cutting it down 2 weeks ago. My sick apple trees also have sings of woodpeckers. They are sick with a fungus infection. For the apple trees bugs get in the stressed trees. One dead and another struggling. Once bark is loose you know you were too late to save anything. I live in Georgia where we have enough pine beetle. When I visited Colorado in 1977 and 1978 the mountains were dotted with dead pines from beetles..
😮😮😮 I have the exact same thing happening to MY Apple trees!!!! (I’m in Ontario, Canada though). They have some kind of fungus…no one seems to able to tell me what it is. It’s slowly killing the branches…but the APPLES!!! 😮😮 Two trees…I pick up 1500-2000 little green apples off the ground in early spring…and then I literally get THOUSANDS of apples.
🤷‍♀️🤷‍♀️🤷‍♀️ I don’t know how trees can look so terrible yet produce like crazy.
I’m reading this thread because I’ve got some issues with pine trees as well. But also have something killing all my spruce trees from the bottom up. Some kind of fungus, that again, no one can identify. 🤦‍♀️ I think the problem is two-fold…Manitoba (swamp) maples that grow like weeds have taken over the outer perimeter of my property and shading the spruces too much (been working on THAT problem with the chainsaw…) but the other thing is that in June 2017 a massive flood came through my property. My property acted like a funnel and came through the 4 acres at 5’ high. Oh yah. Not kidding.
It was right after most people had finished spraying, and when the river receded it left behind inches of clay that covered EVERYTHING. Trees, fence posts, barn, hay shelter- everything was covered in clay where the water had risen to. Now this fungus is rampant- all over my cedar posts and it’s literally destroying the wood. Same thing with the Spruces- whatever branches have this fungus on it (now spreading to entire trees), the needles will drop and the branch dies. Even the walls of the buildings are starting to deteriorate wherever the residual clay was left behind. What an utter mess.😩
I don’t know if it is something systemic that is now in the soil, or if pesticides did a number on them, or what is going on. 😩 So, if you have any insight… I’d appreciate it. BTW- I never used to spray my Apple trees, but last year I did- with Lime Sulphur -hoping it would take care of the fungus. Didn’t work. So I don’t know what else to try - on them OR my spruces. 😔 Thanks for any advice you can offer! Patti 😊
/ What causes this pine tree problem? #64
patti24 How to Get Rid of Stink Bugs | Updated for 2021
I had two blueberry bushes planted a foot apart. Some sort of fungus or mildew killed the one plant and tried to get the other. Blueberry yield significantly down this year.
I cut down one cedar too close to the apple tree. Other apple tree dead and cut down a month ago. Friend brought over two apple trees. I need to figure out where to plant.
/ What causes this pine tree problem? #65
Thanks! I’ll save this for reference re:Fungicide Application Rates.
However, this isn’t what is attacking my Apple trees, and my Cedars are all fine. It’s just my Spruce (and some pine) that are dying.
/ What causes this pine tree problem? #67
I was thinking The Mountain Pine Beetle problem that devastaed BC, but not sure if that is even a concern in Texas. All the best.
/ What causes this pine tree problem? #68
it reminds me of Porcupine eating patch .... they eat the inner bark of trees, like hemlock, spruce, white and pitch pine, basswood, sugar and striped maple, beech, birch, aspen, ash, cherry, apple and other species.
/ What causes this pine tree problem? #69
pine beetles bore holes inside the tree and not eating the bark... unless you are thinking the pine beetle killed the tree and the bark pealed because of it ?
I need to get out there with the saw and get more evidence. Last day of school today, so I should have some time in the next couple of weeks. I'll have to buy a new saw...waiting on a part for the last 3 months...
Good news is we finally have someone coming out to clear land for the shop and house...in about another month...if I can get the shop built we can get the tractor and do more of the work ourselves.
/ What causes this pine tree problem? #72
This is the pine bark beetle, which are usually attracted to stressed trees, mainly from droughts. If you had a period of drought, the tree stresses and the pine bark beetle can smell it. They drill small holes into the bark and chow on the outer cambium. Once you notice the small holes, it's over. The pic you posted is a year+ of death.
If you're going to experience drought, watering the tree if possible is the solution. You can also spray around the based of the tree up as high as you can go to prevent burrowing. "There are currently 3 insecticides registered for control of bark beetles on southern pines. These are lindane, chlorpyrifos (Dursban 4E) and fenitrothion (Sumithion 8E) . Landowners may purchase lindane for their own use without an applicator's license."
/ What causes this pine tree problem? #73
got 4 here by the road dying----a friend says its from some bacteria they picked up out of the soil. I have no idea. I planted a couple more 20 feet away from the dying ones and they too are showing signs just like the big guys! -- Well come hell or high water,--- I am going to have evergreens down by the road so I went into sis's timber an dug up a bunch of cedar trees and they are growing like weeds! so we are getting a cedar screen in place of the pines.
I thought pine beetles too but cant find any on these trees.
/ What causes this pine tree problem? #74
Interesting point about the bacteria. I am having trouble with a lot of trees dying- both evergreen- Pine & Spruce and deciduous- mainly my Apple trees. They die from the bottom up, and usually are covered with something that looks like moss/mold/fungus/algae (no one has been able to identify it🙄) My property was hit with a massive flood in 2017, and things have been going downhill since then. Even my cedar fence posts have this and are rotting! And interestingly enough, my horses- who have never had thrush in their lives- both had it in all 4 hooves. It took me over a year of trying every kind of product imaginable to get it ‘under control’, but I am constantly fighting it. My farrier knows how I look after their feet, so we have come to the conclusion that in the INCHES of clay that was left behind when the river receded, there was some kind of bacteria/fungus/virus whatever that remained in the soil. 🤦‍♀️
One other possible cause of the pine trees dying could be a shrub called ‘Russian Black Currant.’ Apparently they contain something that adversely affects pine trees and kills them. ??? I have one of these black currant bushes about 100’ away from some of my pines, so that may be causing some issues. 🤷‍♀️ Doesn’t matter to me though, because these big 40 or 50 footers are coming down VERY soon!!
Pools, decks & pine needles don’t mix!! (But I AM reclaiming the wood and using it inside my 1857 log cabin 😊)
Patti
/ What causes this pine tree problem? #75
There's an anti-fungal product w the active ingredient called propiconazole. this mixed into the soil at proper dilution rates will definitely kill any fungus. Via macro-injections, you can also treat a tree, but it needs be done proactively.
Sorry about your pines...and cedar are like weeds and nothing kills them but droughts
/ What causes this pine tree problem? #76
Thank you!! I’ll get some of that this week! Could I use it at the base of my Apple trees as well? What about spraying trunks & limbs of all the trees that have this fungus, (or whatever it is) that is making the bark fall off? Will it work with topical application? Thanks for your help! Patti
/ What causes this pine tree problem? #77
Here’s the product that i used for macro & micro injections as well as topical /foliar grass spray
Call the manufacturer and tell them of your specific issues w as much detail as possible as if Kestrel will work or not.
I would also call your county extension agent too.
If this truly is a fungus, you could buy a small amt and test it.
Finally, in any tree application, once a tree is in a lot of stress, post stress remedies are much harder to treat than prior to any pathogen attacking it’s host. It’s much like cancer, early detection is the key, but w trees sometimes that’s really difficult. Therefore, proactive measures to preclude a pathogen is very critical. Just see what the manufacturer states after you provide your detail, then post back.
Good luck
/ What causes this pine tree problem? #78
Good luck
Thanks for all that detailed information!! I’ll give it a try- probably not until Fall- don’t have the time at the moment! Thanks again!!
Patti
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
2012 PETERBILT 386 (INOPERABLE) (A65643)
2012 PETERBILT 386...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
