Something I don't understand about applications of below 40hp tractors
   / Something I don't understand about applications of below 40hp tractors #91
About 1950. My Dad plowing with only TWO horsepower!
   / Something I don't understand about applications of below 40hp tractors #92
The whole problem with this thread is, you are all comparing, all the different tractors by HP!
The old tractors are built more than twice tougher than the compacts you guys are comparing them too!
SR
Really ?
Here is an example of what I'm talking about
According to tractor data
Ford 8n, 30hp, 27 pto hp = 2410-2717 lbs
Modern Kubota l2501, 25hp, 20.5 pto hp = 2425-2623lbs
Your saying these older under 40hp tractors were twice tougher than modern compacts yet they weigh about the same, how can that be ??
   / Something I don't understand about applications of below 40hp tractors #93
SR
Somewhere between 100 and 150 hp. My 80 hp skid steer can’t come even close to hanging with it.
   / Something I don't understand about applications of below 40hp tractors #94
Really ?
That's exactly what I'm saying...
I already know that one of my yuppie tinkertoy tractors won't hold up to working at the level of something like an old Farmall H!
Only someone's "pampered poche" of today, will still be around 50 years from now. UNLESS it's already been melted down and made into something else!
SR
   / Something I don't understand about applications of below 40hp tractors #95
Thank You for the interesting History lesson!
"While Ferguson may have been willing to take initial losses on his tractor and equipment sales in the name of solving world hunger, his idealistic nature blinded him to the fact that he was the only one who was. As he dropped his own prices to economically unsustainable amounts, sellers pocketed the difference rather than passing on the savings to consumers, fatally wounding Ferguson’s bottom line in business and puncturing another big hole in his faith in humanity."
Harry Ferguson and the Three-Point Hitch - Mecum …
Well Worth the read. Sad Commentary. On 'Us'. He'll be one of the first when Awakened, i would think.
Too inherently lazy to check the original patent date(s) and the duration of patents back then. or too "Do the math". Even barefoot as i type.
Seems like CONgress 'extended' the patent on Viagra®. Twice.
Small wonder, hard as things were on people back then.
Interesting first post. 👍
Welcome to TBN!
   / Something I don't understand about applications of below 40hp tractors #96
Are the stumps visible and how big are they? When you say lots of trees, do you mean every 10 feet or every 50 feet? You might need bigger equipment to rip out/ dig up existing stumps and roots, then use the tractor for plowing/upkeep.
I see a lot of Ford 1100 and 1210, etc. for sale around my area for 4 to 5 grand in good condition. They are 4-wheel drive and should do everything you want to on that acre for gardening/general purpose upkeep.
I've read every post, and this is the best/most logical I've seen. Clearing the land should be a one-shot deal. I piddled on mine for 7 years before somebody wanted to cut the woodlot behind me and asked if they could put a road up into my field. They hauled in around 100 yards of gravel screenings for a road and the only thing I asked was that they clear the trees off the old 2 acre field which it went through. Harvester.JPG
I then had them cut 2 more acres... in return they came in with an excavator and in 2 days converted a field of stumps into something I can work with.
If the operator knows what he's doing he should be able to do about an acre a day. You can have him bury the stumps but instead I had them piled up. Now the stumps have rotted down and I'm in the process of reclaiming the soil.
   / Something I don't understand about applications of below 40hp tractors #97
I read you don't plough with any tractor under 40hp. At least maybe not on a new unworked field. Don't know if that's right, but it is what I have been reading on more than one site.
If you don't have a front loader or a lawn cutting pull behind implement, what do you use them for? For example, I found a good price on a Kubota B6000e. It is only the tractor. I can only cut the grass with it?
Are all the old tractors over 40hp?
Edit:. I read the Kubota was 10.5 hp. My jd L110 is 17.5, but no pto. I don't know what I'd do with the Kubota.
Couldn't be further from the truth.
Only if you qualify the variables/specs on those conditions that might make that statement true.
After reading everyone's response, maybe how much should a tractor weigh might be better for unplowed land.
   / Something I don't understand about applications of below 40hp tractors #99
Nailed it. Most everyone worries about HP when starting out (me included) when weight should be the first consideration. When working raw land, clearance or lack of it can stop you no matter the HP or weight. Once you think through it, it makes all the sense in the world.
   / Something I don't understand about applications of below 40hp tractors #100
Having appropriate tires helps a lot too, plowing with ag tires is a lot easier than with turf tires.
Auger Drill Bit (A56857)
Auger Drill Bit...
2019 GALYEAN...
2016 Peterbilt 337 Corrosive Flammable Liquid Transport Truck (A55973)
2016 Peterbilt 337...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
