harbor freight weed burner
   / harbor freight weed burner #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
Got it hooked up & got propane in the tank, but when I pull the trigger it gives me a short instant of higher flow and then dies immediately
   / harbor freight weed burner #2
Many of the new valves still have the LH thread on the inside. At least on RV tanks.
   / harbor freight weed burner #3
sounds like wrong tank for the fitting. or wrong fitting for the tank.
Maybe a adapter is available
   / harbor freight weed burner #4
Weird, I use that fitting with propane bottles on my cutting torch.
   / harbor freight weed burner #6
Is this a brand New torch or an older one, Harbor Freight had a recall on those a while back
   / harbor freight weed burner #7
"All propane tanks built in the last years have an excessive flow regulator. If it senses a leak in your system it dramatically reduces the flow out of the tank. This often happens if you have a burner in the on position when you open the propane tank.
Maybe try going slow to full burn? Just a thought
   / harbor freight weed burner #8
What size tank are you putting it on?
6 Trench attachment (A50322)
6 Trench...
1998 JOHN DEERE 310E BACKHOE (A51242)
1998 JOHN DEERE...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
