Are special tools needed to replace a clutch on a compact tractor?
   / Are special tools needed to replace a clutch on a compact tractor?
Did the dealer mean a puller was needed to remove the pilot bearing?
I am not sure. He didn't mention the pilot bearing. I may call them back and ask.
   / Are special tools needed to replace a clutch on a compact tractor? #12
If you find you need a puller for sure, $2200 can buy a lot of tools.
   / Are special tools needed to replace a clutch on a compact tractor? #15
OK. Thanks.
Also, you can use an automotive style alignment tool when installing the new clutch. Remember to make sure that it fits the NEW pilot bearing snuggly.
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
