Recommended Tractor for 4.5 acres
/ Recommended Tractor for 4.5 acres #121
I am sorry that your tractor has needed the dealer so much. I haven't had mine into the dealer since I bought it.
Don’t be sorry for me I just got my seafood fix and have gotten over the issues the John Deere had long ago. We have been very happy with the Kioti it has proved to be a very dependable replacement and hasn’t had any issues.
Glad you haven’t had issues. Most I talk to think the LS is a good tractor and I haven’t heard one complaint from those around with them.
Janet
/ Recommended Tractor for 4.5 acres #122
I have the Yanmar YT235C backhoe & loader
no problems works great for me. A/C keeps
me nice and kool at 107 degrees and has all
the power I need. Plus the backhoe works much
better than a shovel! Cheap on fuel and a very
nice warranty to go with it!
LS blue is a nice tractor and they are expanding
willy
/ Recommended Tractor for 4.5 acres #123
Hello! I’m under contract on a house with about 4.5 acres (1.1 ac wooded) and would like some opinions.
Most of the property is grassland, so mowing would be the most frequent usage. It has a 300’ dirt driveway and the property needs some grading and dirt work near the foundation, so I’d like a box blade. After the initial grading, the box blade usage will be seasonal for driveway maintenance.
The current owner is using a zero turn mower, but about an acre of the property is severely overgrown. I’d prefer a fail mower to a brush hog for maneuverability.
It also has a hobby farm set up that we’ll continue to use, so the loader will be handy.
It’s in Kansas, so some snow, but not in huge quantities… usually.
I was originally looking at the Kubota BX2380 and Deere 1025R. I’m leaning to Kubota, but it looks like I can get a B2301 for only $1000 more.
This will be my first tractor, but I often used my dad’s Deere 4310 when I was in high school on about the same amount of land. He lives in a state with a lot of snow, so it’s mostly used as a plow.
Are there any other contenders I should look at? And is the B01 worth the price jump over the BX?
Thanks!
I would recommend the largest tractor you can justify possibly the l2501 Kubota. Larger tractors are more stable for loader work and more comfortable on rough ground because of the larger tire size
/ Recommended Tractor for 4.5 acres #124
Except now they pronounce "Branson" as "TYM". Not trying to start anything, just keeping it real.
I love my Branson. It's been rock solid. Over 5 years and over 300 hours without needing any repairs. But my dealer is gone, and so far the only TYM dealer is on the other end of the state. Sure hope they can keep it growing.
Sounds to me like you have a business opportunity...Slowpoke Slim's Equipment - Central ND's home for Branson, TYM and Bad Boy. :)
/ Recommended Tractor for 4.5 acres #125
Limit yourself to whatever color has a good cheerful and cooperative dealer near by. YOU WILL have continuing needs to work with a dealer be it questions, parts, upgrades, repairs -- dealers are very nearly more important than whatever brand they sell. Ask around. See what the farmers (even weekend farmers) say about the local dealers. Valuable.
I’m a weekend farmer but mileage wise I drive “past” three closer dealers to get to my tractor’s color dealer. I drive past one to get to my favorite dealership ever but they only sold me my baler and implements. Both are more than a four hour round trip, nearest dealers would still be 2-2.5 hour round trip. I’d argue look at the machine first then decide who you want to work with, like JWR said talk to the locals and they will have a favorite (that’s how I found my favorite tractor dealer so far away).
/ Recommended Tractor for 4.5 acres #126
I’ll take a look at those as well. I’d be lying if country of origin wasn’t a concern of mine though. Thanks for the recommendation!
Thanks for the models, I’ll have to see if there’s a dealer near me.
I think his is a 30 horse model. I didn’t look that high up the range because we never really used it to it’s capability, I always thought it was too much tractor for the land. I’m quickly seeing that was the wrong assumption. Unfortunately, $25k is already towards the top of my price range, so I don’t know that I could go much bigger unless some of the other brands are considerably cheaper.
Thanks for the advice.
Don’t forget to look at Kioti. A CK 3510 - 35 hp. That’s what I have for my 5.5 acre hobby farm
/ Recommended Tractor for 4.5 acres #127
Thanks!
For smaller acreage I would say a skid steer or similar, they have many attachments and are more maneuverable.
/ Recommended Tractor for 4.5 acres #128
Thanks!
I got 9.37 acres and have had bigger tractors. I bought a GC1728 Massey. The bigger tractor could pick up 3000 #. The little Massey is rated 600# but I can get the Massey in places the big tractor would not fit. I'm not surpriece
Thanks!
Thanks!
I would get a tractor that is newer to have a Quick change bucket. I can go from a bucket to forks to Grabble. Less that 10 minutes to change. I got a Massey and I would not have a John Deere. The John Deere quick change will only work on John Deere. The John Deere bucket, forks, and gabble cost a lot more.
/ Recommended Tractor for 4.5 acres #129
Started out with a 1968 mf 135 with FEL used,. got tired of fixing and got 1999 jd 4600 with FEL ( kept MF because I can always use it to pull out the tractor from our wet ground)), With this level 43 hp you can run a chipper (started with bearcat pto 70554 5" then got a woodmax 9900 big throat hydraulic feed ..they sAy 9" but really 5-6" is more realistic) to take care of downed trees/ or 35 fruit tree prunings and chips double as bedding for critters or landscape mulch). have 12 acres and now wish I'd gotten more hp. Don't know how much tree work you'll have to do. In SW wash state storms regularly down trees/branches.don't buy a backhoe, Rent anything requiring a big dollar layout or some thing you won't use at on a regular basis.
if buying a tiller make it as wide as tires, here I started with troy built rear tine tiller but got a 6 ft Howard and now can till both 50x100 gardens in 1/8 time vs walk behind. the cost of a rear tine rototiller walk behind is close to 3 pt tiller but you save soo much time and with better tillage but then 1use it only twice a year but I till all the neighbors gardens and chip neighbors trees..( I also have a pto manure spreader I chip neighbors trees/limbs and dump in my cow padock).
i Love my Seppi M 7 ft flail sml will chop up to 3/4 " limbs is reverse rotAting and mulches everything down to 3/4' tall grass, I can also clip the "Pizza grass" for the cows/ goats ( cows if you get some like tender new grass and you see pastures where the grass is very high in 1 spot and low in others this is called pizza grass and if you clip the tops off the regrowth is tender and they'll graze it ) just stay clear of rocks, ......so I always rent backhoe, post hole digger, in your case because of the food plots a tiller might be a good buy because you'll probably have to rent tractor with the tiller, box blade is handy but don't use it much or the angled back blade.
/ Recommended Tractor for 4.5 acres #130
when i was shopping the nearest LS dealer offered me a mt342 with loader for 24k and change. that is a MUCHHHHHH more capable tractor than the SCUTs you are looking at. IMO the only real reason not to use a medium sized CUT is if the SCUT is the only thing you can get into the places you need to use it. but on that note my huge 5145 is so much more maneuverable than my old ford 2000 with manual steering and it weighs close to twice as much.
Did you dive Into the MT125 and the MT225E? The MT125 is the best deal I have found with FEL, MMBM and backhoe for 25
/ Recommended Tractor for 4.5 acres #131
i hear you, get comfortable with the dealer first, but IMO if i was comfortable with the dealer and had the ability to haul the tractor, 90 miles if it is good roads is not that much more trouble than a 25 mile drive considering the work involved in connecting the trailer loading and securing the tractor and then have to leave it at the dealer for 3 days before they can look at it etc.
LS has a great lineup and very attractive pricing right now and that is comming from someone who just bought and loves a Mahindra.
Going to look at the MT125 this weekend. The MT225 seems to be a much more capable tractor for only 4 k more…
/ Recommended Tractor for 4.5 acres #132
I have an M4 and MX and often wish I had not sold my BX. But if I had to limit myself to one…it wouldn’t be a BX, B would be as small as I ever go as a single unit I think.
I also have a MC 5400 and a BX 1880. I think a B series for the acreage you have and needs you stated would be the minimum. I also have a zero turn. If I had it to do over again I would have gone with the L2501 and a zero turn.
/ Recommended Tractor for 4.5 acres #133
That’s what I have, L2501 and a zero turn for similar acreage.
Mike
/ Recommended Tractor for 4.5 acres #134
In my experience for new implements the JD quick attach is not that mush more expensive, most implement manufacturers make both. if you are looking at used I find that i can come across 5 skid steer QAs for every JD version, but the price is close there also. YMMV.
I can understand the need for a smaller tractor but that does not apply for me, the 5145 gets into any place i need it to, but it is a little hard on the grass being so heavy. I just never saw the utility of a FEL rated for less that 2000# but that is just me.
/ Recommended Tractor for 4.5 acres #135
I did not look into those other than to dismiss them, i'm a big guy and in the end it came down to an operator station that i thought i could spend all day in comfortably. I was also interested in something over 30HP at a min, Yes I know that a 25hp will do most of what you need, but i tend to buy something and the drive the wheels off then bring out the duct tape to put them back on for another 200k miles, so i wanted to make sure i had more than enough of everything to avoid buying a better tractor later. Also in my research i found out that the good enough MT342 was only 5k cheaper that the more that enough 5145, with 0% financing on the mahindra and 2.99% on the LS the diff was insignificant. i was replacing my hand me down ford 2000 in which the time meter stopped working at 6999.
Anyway the LS IMO is a good brand and has a lot of features built in for a very good price.
The MMBM is not for me and is not an option for the MT342 (as i recall so don't take my word for it), I have a ZTM and a brush hog.
one thing that the MT342 had that i wish was on the 5145 is the rear 3ph adjustment lever and the MT342 has 2 rear remotes standard. I'm not crazy about the turbo engine on the LS but could have lived with it. also LS would not allow me to own the factory service manual which in the end killed it for me. Again not bashing LS these things are important to me but not so much for others.
/ Recommended Tractor for 4.5 acres #136
John deere 9series. Probably go with duals all around. Maybe triples if you mow a lot
What mower for that? Ideally, the OP would want to get the whole 3 acres of grass done in 5 min or less, or 2 passes.
/ Recommended Tractor for 4.5 acres #137
Extra wide to get around trees and under fence lines. 🤣
/ Recommended Tractor for 4.5 acres #138
For sure you would want all tires filled with rimguard too. Those batwing mowers pull hard, and besides, how often does a tractor owner say, "boy, I wish I had less traction!"
/ Recommended Tractor for 4.5 acres #139
never, but i often wish for less damage to my lawn
/ Recommended Tractor for 4.5 acres #140
Yes, There is such a thing as too big a tractor. Though it is a bit of a unicorn on this site ;)
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
1994 Freightliner Day Cab (A62613)
1994 Freightliner...
more info coming soon! (A61569)
more info coming...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
17601CFL (A59228)
17601CFL (A59228)
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
