CUB CADET BDU10L TRANSMISSION MAX TORQUE!
   / CUB CADET BDU10L TRANSMISSION MAX TORQUE!
Also go to tuff torqs website and look at the k92 and it says 882nm or 650ftlbs of torque.
   / CUB CADET BDU10L TRANSMISSION MAX TORQUE! #12
Thats for JUST THE PUMP itself. The actual final torque spec of the transmission is then the pump is in the transmission housing with the gears with the final reduction ratio. Using the specs that they use you can use the reduction ratio to find the actual torque of the pump+transaxle and gears. Thats what everyone is not understanding no offense.
The specs I linked to says it’s for the transmission.
Thats because hydro gear calls them transmissions for some reason.
   / CUB CADET BDU10L TRANSMISSION MAX TORQUE! #14
it is called a transmission because it contains both the pump and the drive motor. What people are missing is that BDU10L isn't directly connected to the wheels. It is connected to a gear reduction transaxle that results in torque multiplication.
So basically if you reduce the 85 in-lbf from 3600 rpm down to 50 rpm that 85 in-lbf gets multiplied to 510 lb-ft
   / CUB CADET BDU10L TRANSMISSION MAX TORQUE! #15
The pump IS the transmission. Gears have nothing to do with it. The transmission is only rated for 208 pound feet of torque.
If it’s run through a gear reduction, the torque is increased by the gear reduction, not the transmission.
They are two separate items, even if one is directly mounted to the other.
Yes, yes! That’s exactly what im trying to say. 510 actually sounds more real.
Yes they do! Gear reduction!
   / CUB CADET BDU10L TRANSMISSION MAX TORQUE! #18
Everybody is arguing the same point from different directions. The BDU10L has a potential of 208 in-lb torque at the output shaft. What is confusing everybody is what Hydro-gear calls a transmission is better described at a hydraulic power unit HPU. That HPU is always connected to a transaxle in like a mower differential. Which is were the torque multiplication falls into place to get the high torque ratings.
So that 208 in-lb at the HPU output can easily become several hundred lb-ft at the wheels of the piece of equipment.
Thank you randy! That’s exactly what needed to be said.
   / CUB CADET BDU10L TRANSMISSION MAX TORQUE! #20
Yes, that’s what you should have said. Because the subject is BDU-10L Transmission max torque and the manufacturer of the BDU-10L says it’s 208 pound feet.
GMC 2500HD 4wd Service Truck (A56436)
GMC 2500HD 4wd...
22 In Heavy Duty Mini-Excavator Bucket (New/Unused) (A59225)
22 In Heavy Duty...
2006 Dodge 3500 (A57148)
2006 Dodge 3500...
ALLISON TRANSMISSION (A55745)
ALLISON...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
