Why not sugar water in tires instead of beet juice?
   / Why not sugar water in tires instead of beet juice? #101
What are you finding in a price per gallon, for the RV?
The best sale was $1 for 1-gallon back in 2018. Walmart was clearing the shelves of it. :)
Other sales were $1.59 and $2.19 compared to full price.
   / Why not sugar water in tires instead of beet juice? #102
First question I'd have asked is "What the heck grade of stainless are they made from?" Second would be "They did fire the idiot engineer who specced them yes?"
It irks me when people make smart-ass derogatory replies. Having spent 40 years as a food processing engineer, I have seen a lot of stainless steel that was badly corroded. From worse to better; 304, 304L, 316, 316L, and 317L, are the common commercial grades available suitable for corrosive conditions. All of them can and do corrode under certain circumstances. Cost becomes a major factor, availability from suppliers becomes a factor. Sometimes you can only use what you can get. The more exotic alloys like Titanium, Hastelloy and Inconel may be appropriate in a lab, but are seldom a practical or cost effective solution for most industrial installations (there are exceptions). Improper sanitation procedures by under-trained sanitation crews is a common and major factor. Perhaps the inexperience of an engineer might be a cause, but usually the stupidity of the engineer is pretty dang low on the list of factors.
Plastic components are often a better corrosion resistant solution, but sometimes you can't use plastic because of strength or temperature considerations.
In regards to the OPs situation; I'd be reluctant to use sugar water. There are to many unknowns. Corrosion may be an issue, especially if the tires are tubeless. If the concentration is high, I can see the sugar coming out of solution at cold temperatures potentially causing issues. It may work but has unknown risks. If you don't want to take the time and expense to go somewhere for beet juice, then windshield washer fluid is the probably the most affordable option that you can do fairly easily by yourself.
   / Why not sugar water in tires instead of beet juice? #103
I've often imagined the utility of a Boat hull clad in inconell. Imagine the Maintainance issues one wouldn't have. no barnacles. no corrosion, no antifouling painting, no zinc ingots.
   / Why not sugar water in tires instead of beet juice? #104
No money left in your bank account :)
   / Why not sugar water in tires instead of beet juice? #105
I assume beet juice is used because of all the sugar dissolved into the beet juice.
Why do you assume that? Does the presence of Sugar inhibit corrosion? Beet juice has some natural corrosion inhibitiors.
In theory, you could use a water soluble and biodegradable Machining cutting fluid concentrate. Maybe a gallon per tire mixed with water. I was considering that and then I realized I already owned a huge steel box I wasn't using.
   / Why not sugar water in tires instead of beet juice? #106
you need something to inhibit corrosion
I threw a couple of bottles of radiator anti rust in each water filled tire. Made for rubber and all metals.
   / Why not sugar water in tires instead of beet juice? #107
Raul-02,
Not to burst your bubble on NiCr bearing metals ( Inconell ) but they are subject to fouling. USN is focused on some really interesting surface texture types that prevent organic material from attaching to the surface as fouling costs a billion+ dollars a year to manage.
Little abstract for your viewing pleasure.
In a marine environment solid surfaces are subject to corrosion and fouling, which is the buildup of unwanted material such as algae and barnacles, that can impede the functionality of components. The application that this project focuses on are hydraulic cylinders. Eight alloys, including three newly developed alloys, were tested for marine fouling performance. Three of the alloys were primarily NiCr, these included Inconel 625, Metco 1720, and P105-X3. Four alloys contained varying amounts of Cu, and these were Monel 400, CuproNickel, Monel 450, and P76-X24. Finally, one sample of a Co-based alloy was also tested, Ultimet. Of the samples tested, Metco 1720, P105-X3, and P76-X24 were developed by Oerlikon Metco, a company that focuses on new alloy development, characterization, and testing. The other alloys are commercially available. The samples were immersed in the ocean at the Cal Poly Pier for nine weeks before being removed to assess how each alloy performed in a marine environment. Built up fouling was quantitatively measured by mass of fouling and surface area covered by fouling. Corrosion was assessed using mass lost to corrosion as well as visual inspection. Of the NiCr alloys, Inconel 625 was the least fouled with 0.5882g of fouling covering 28.29% of the surface, and P105-X3 was the most fouled with 1.7423g of fouling covering 48.66% of the surface. A correlation was found between amassed fouling and the presence of hard phases in the alloys. With the Cu containing alloys, the fouling resistance was largely controlled by the Cu content; more Cu resulted in better resistance to fouling. The exception was the P76-X24 with 16% Cu, which exhibited a fouling resistance equivalent to that of Monel 400 which has 30% Cu. The Ultimet was the most fouled sample with a mass of 1.7567g covering 61.23% of the surface.
   / Why not sugar water in tires instead of beet juice? #108
So a Copper bottomed boat may be better than an Inconel bottomed boat. I will keep that in mind the next time I want to put a new bottom coating on my yacht. But I would bet gold might work even better.
   / Why not sugar water in tires instead of beet juice? #109
In order of best to worst for metals capable of controlling biological growth ( fouling ) Lead, silver, copper.
EPA has banned lead, silver is way to expensive, so that leaves copper.
Ever wonder why older homes have a strip directly below a chimney that always stays clean? Erosion of the copper flashing around the chimney and running down the roof and kills algae growth on roof directly below chimney.
Gold being essentially nonreactive has no effect on biologics.
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
Butterfly Artwork (A55758)
Butterfly Artwork...
2306 (A58376)
2306 (A58376)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 International DuraStar 4300 18ft. Reefer Box Truck (A56858)
2018 International...
