Jinma 284 Tach died
/ Jinma 284 Tach died #1
piper184
Central, ND
Jinma 284
2006 Jinma 284 with Y385 engine. All working fine on a rather warm day. Shut down for a cold drink and re-fuel. When started back up tach was dead. No flaky behavior prior to this, working one minute and dead the next.
All other instruments working. Looking at a wiring diagram it appears that the entire cluster gets power from the same source and since that is working, it has to be something else.Disconnected the sensor at the plug and it was in rough shape. Testing the sensor for continuity it was open. Testing the tachometer end at the plug showed about 38 ohms of resistance. Put the ohm meter on AC voltage and spun the engine with the starter and decompression, no change in reading of 0.0 volts.
Removed the sensor and it showed that it had been scraped on the end by what appeared to be ring gear teeth. Not bad, but a minor scratch. This was the factory installed sensor from 850 hours ago, I have never touched it. No debris on the sensor and it had a slight magnetic field to it. I gently filed out the scratches and polished the end and cleaned again. Still no continuity and reinstalled on the tractor. Turned in until it touched, then backed out 2/3 of a turn. Again spinning the engine showed no voltage on the AC scale of the multimeter.
For ~ $40 I have already ordered a new sensor. Even if that is not the problem, it won't hurt to have a spare on hand at that price.
My question is, how did that scratch get in the sensor? Dumb me didn't take a picture before I filed it out. Is it possible that the engine crankshaft has developed enough end play to have damaged the sensor after so many trouble free hours? I can see no signs of other wear or any oil leaking from the rear main seal.
Should I be able to try prying on the damper pulley to check for end play, just in case something more serious is wrong?
Is it possible that the sensor scratch was done at the factory and actually has no role in the sensor going bad?
Any and all ideas are welcome. TIA
/ Jinma 284 Tach died #2
The sensor is actually a reluctor. Think of it as a tooth counter. It produces a square wave chopped AC signal. It's the same as a WSS (wheel speed sensor) found in cars and trucks. There is actually no continuity. I had mine out for cleaning and checking awhile back and found a few light scratches, but it still works fine. Most of the ones I've seen are the Hall Effect type with a single pole at the tip. It's possible that you have it backed out too far, 1/2 turn is recommended as tightening the jam nut brings it out a little more. IMO, the magnet has passed the threshold of being effective, so is likely the culprit. That said, my integrated hour meter failed at 650 hours but I wasn't going to spend $200+ for a new unit so I installed an aftermarket meter.
Yeah, I figured it was a reluctor. They have a coil inside so I thought there should be some resistance. I even have a listing where someone had measured it and got a little resistance, not just open.
The information I found said either 1/2 turn or 3/4 turn back out after contact. I split the difference. I guess now that I have order confirmation, I can go ahead and risk closing the gap a little. Also, probably wouldn't hurt to cut off the plug and strip the wires back for a little better test of continuity. With the dodgy wire and connectors, I might just upgrade both sides of the plug to a better connector. I will have to see what I have on hand.
Thanks for the link Bob. Good info indeed. I find it interesting that Jinma chose to mount the sensor 90 degrees to the ring gear instead of in line with the teeth as shown by Murphy. The Jinma method would seem less effective and is prone to issues caused by any run out at the ring gear. I'm glad they mentioned putting a load on the circuit to test for voltage. Duh, if I had thought it through I would have known that. I bet my el-chepo multi-meter doesn't have sufficient internal resistance to work the way I was using it. Priority this week is haying so it may be a few days before I can update this post.
/ Jinma 284 Tach died #6
I wish I'd known about the loading a long time ago too. Wish I still had my Simpson 260.
Good news, bad news, more good news, more bad news.
Sensor arrived a day earlier than expected and I had time to fiddle with it this afternoon.
I ordered an 18mm sensor when I should have ordered the 15.5 (16) mm one. I didn't see that option when I ordered the first one. Went at the search from a different direction and DANG, there it was. Dumb ass parts guy in the mirror....
Checked the new sensor and like the old, no continuity at the terminals, But I had a drill motor laying on the bench and happened to notice it had a series of nice little grooves cut in the side of the chuck for easy grip. Looked like teeth to me. Flipped the multi-meter to A/C volts and spun up the chuck. As I moved the sensor tip close to the chuck I could see voltage on the meter. Checked the old sensor same way, Nothing. Pretty much confirms I need a new sensor.
Went back online to order the correct part and got all the way through checkout and my browser froze. I had just updated it earlier today. Backed out and tried again, same thing. Called the nice guy at the parts counter and explained the situation. He checked and there were no orders processed but he took care of it over the phone and I should have the correct parts in a few days.
Sheesh!
/ Jinma 284 Tach died #8
Good to know, easy way to test. Now to remember that when needed.....
/ Jinma 284 Tach died #9
I don't see any bad news here, just one instance of not having enough coffee. :LOL:
Using the drill chuck was a brilliant observation. It's all a win-win. Bravo!
Got the correct part in today's mail. Tested with VOM on A/C volts and could see voltage using the drill chuck as a trigger. Installed on tractor and the tach now works!
With the engine idling it was showing about 27 volts on the leads so it is a significant little generator.
Now all I have to do is figure out how to use the mis-ordered part to make a tachometer for my lathe or Shop Smith..... Never waste a good part. ;)
/ Jinma 284 Tach died #11
Where did you get the part from?
My tach died quite a while ago.
/ Jinma 284 Tach died #13
I have a NOS meter you can have to use as a tach readout.
Also,
Thanks Bob,
From what I can tell the DP20 only reads Hz up to 100. If I used a 60 tooth trigger (one pulse per second @ 1 RPM) it would display as a direct RPM number but would only work up to 100 RPM.
Any trigger tooth count other than 60 would require a conversion factor to RPM, which I didn't see in the manual. Easy enough to make a wall chart for reference...
I'm pretty sure the Jinma reluctor puts out a pretty steady voltage and the tach is calculating off of the frequency and would be accurate only for a ring gear with the same number of teeth. Did I miss something?
When I get time I will look at the Murphy site to see what kinds of displays they have.
Thanks for all the info.
/ Jinma 284 Tach died #15
Sorry. What I have is these:
KEP m/n MRHA3M
Red Lion m/n APLVA
Actually, I don't think these would work either, but let me know if you have a use for them.
/ Jinma 284 Tach died #16
Sheesh!
I have a 2010 JM284. The tachometer recently stopped working. This tractor has the cluster instrument panel. The hour meter is integral to the tachometer. All the instruments powered up including the hour meter. So I concluded that either the tachometer sensor unit had failed or the associated wiring/connector had an open circuit. I contacted the dealer who stated the sensor was a common fail item and that there really wasn’t a way to bench check it to confirm a failure. With shipping, a new sensor would be about $45.00. Not a big deal but I figured there had to be a way to determine whether the sensor had failed before spending the money. Then I came across Piper184’s little trick with the drill chuck. Brilliant! On the work bench I connected a DVM to the sensor wires, spun up the drill, and moved the sensor to close proximity of the chuck. I got a voltage reading but it was variable and intermittent. So the sensor was faulty and would need to be replaced. I noted that the wires enter the sensor through a soft rubber cap or plug that fits the end of the sensor unit. Out of curiosity I pried back the plug and discovered the insulation on both wires at the same location had cracked exposing the internal conductors (see photo). I separated the exposed wires so they couldn’t short and repeated the drill trick. This time a steady consistent voltage reading. I wasn’t sure how I was going to repair the wiring because of where the break in insulation was located. I ended up using RTV silicone gasket maker (it’s what I had on hand) to fill the hollow end of the sensor and built up enough silicone to encapsulate the exposed wires and immobilize them (see photo). I allowed 24hrs cure time and reinstalled the sensor. The tach works perfectly.
/ Jinma 284 Tach died #17
Thanks for that tip.
I will have to look into that. Right now I am trying to fix my leaking PS line and gear box.
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
JOHN DEERE 7330 PREMIUM TRACTOR (A62130)
JOHN DEERE 7330...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
JOHN DEERE 2955 TRACTOR (A62130)
JOHN DEERE 2955...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
30 Yard Dumpster (A61166)
30 Yard Dumpster...
