Recommended Tractor for 4.5 acres
/ Recommended Tractor for 4.5 acres #1
Honey Badger 2828
None, yet
Hello! I’m under contract on a house with about 4.5 acres (1.1 ac wooded) and would like some opinions.
Most of the property is grassland, so mowing would be the most frequent usage. It has a 300’ dirt driveway and the property needs some grading and dirt work near the foundation, so I’d like a box blade. After the initial grading, the box blade usage will be seasonal for driveway maintenance.
The current owner is using a zero turn mower, but about an acre of the property is severely overgrown. I’d prefer a fail mower to a brush hog for maneuverability.
It also has a hobby farm set up that we’ll continue to use, so the loader will be handy.
It’s in Kansas, so some snow, but not in huge quantities… usually.
I was originally looking at the Kubota BX2380 and Deere 1025R. I’m leaning to Kubota, but it looks like I can get a B2301 for only $1000 more.
This will be my first tractor, but I often used my dad’s Deere 4310 when I was in high school on about the same amount of land. He lives in a state with a lot of snow, so it’s mostly used as a plow.
Are there any other contenders I should look at? And is the B01 worth the price jump over the BX?
Thanks!
/ Recommended Tractor for 4.5 acres #2
Honey Badger 2828,
Welcome to TBN.
Without asking what your big picture is, now or into the future, I would make the following three suggestions.
First: The BX230 machine has a front loader the B2301 does not so you are ahead of the game by having a front loader and what it enables you to do, otherwise they are essentially the same machine.
Second: The biggest mistake first time tractor owners make is buying too little machine. As you get used to using the tractor, you will want to do more and that requires weight and horse power.
Three: A tractor is only as good as the implements/ attachments that you can add to it to get work done. By having a loader, you have already checked off a major attachment.
/ Recommended Tractor for 4.5 acres #3
The loader is paramount IMO (agree with M59). You'll do far more work with the loader than you will with a box blade. I have a ¼ mile drive, and I use a landscape rake to "rough" groom it, and the FEL to do the final back drag to give it a finished look.
The landscape rake is also used to move brush, limbs, leaves, and smooth out other areas. If you get one that rotates 180°, you can also use it for a snow plow. (Just make sure to get one wider than your wheels)
Once you become proficient with the FEL, the box blade will sit in the corner.
Just my 2¢
Thanks for the replies. And sorry for the confusion, but I’ll be getting the loader for either. It looks like the B2301 FEL has about 200 pounds of lifting capacity over the BX2380 (948 vs. 739).
The attachments I’d be looking to buy at the jump are the loader, belly mower, box blade, and maybe a brush hog or flail mower.
Is a loader easier to use than a box blade for creating a slope away from a foundation?
/ Recommended Tractor for 4.5 acres #5
While my FEL is used for everything I can. The Box is the king when it comes to putting gravel back on a driveway or fixing potholes after a big storm. Even when I use the loader to haul rock up the hills I drag a full box behind me, then dumping and spreading at the same time. Lord knows I move a lot of rock. Now if I have to pick one FEL is on top does a lot things. I guess the rake would do some of work but I can't see it being useful when you have to rebuild a road that washed 1/4 mile of rock down to the bottom.
I've worn through bottom of my FEL bucket twice having to weld in new steel and the cutting has been replaced. I've also need to rebuild the box again. All edges are 2 to 4 inches shorter than were after the last rebuild..... I maintain a few miles of gravel road in the ozarks.
/ Recommended Tractor for 4.5 acres #8
Hi HB.........
.I'm on 3 acres in Kansas and on my third Kubota with all the common attachments..... Also I have a Cyclone Rake, a Stump Grinder and Chipper. In your case, I'd consider moving up to a HP similiar to your Dad's....i.e. around 40 HP....and then maybe a ZT for yard mowing.
Cheers,
Mike
Don't limit yourself to orange and green. Red (Massey, Mahindra, TYM and Branson) and blue (LS and New Holland) are every bit as capable and usually cost quite a bit less.
I’ll take a look at those as well. I’d be lying if country of origin wasn’t a concern of mine though. Thanks for the recommendation!
A Branson 2515(Heaviest class 25Hp tractor), TYM T25/T264 are some very capable machines.
Thanks for the models, I’ll have to see if there’s a dealer near me.
Hi HB.........
Cheers,
Mike
I think his is a 30 horse model. I didn’t look that high up the range because we never really used it to it’s capability, I always thought it was too much tractor for the land. I’m quickly seeing that was the wrong assumption. Unfortunately, $25k is already towards the top of my price range, so I don’t know that I could go much bigger unless some of the other brands are considerably cheaper.
Thanks for the advice.
/ Recommended Tractor for 4.5 acres #12
You won't regret going with the B series vs BX. However, it sounds like you'd be fine with the BX for your intended uses.
/ Recommended Tractor for 4.5 acres #13
Seriously, 4.5 acres in Kansas (mostly flat I assume) any of the sub compacts will do what you need within reason. The little tractors like the BX are quite capable but you have smaller loader and lift, less side to side stability and less weight. They will do a ton work once you learn their limit and don't pretend it is big tractor. I have 4500 hours on mine and moves dirt and rocks all the time. It small nimble and fits into 4 foot spaces. I like the belly mower for areas my Z turns don't like or when I want gather up some bedding for the rabbits. I will mow serious slopes and knee high grass with few complaints. The 3 point will handle anything for it's class but sometimes I've had to fix implement to get them low enough for the short BX.
The next size up (B series, etc) increases hydraulic power, weight and stability. Will handle some bigger tools and you might see over the weeds instead of into them as you brush hog. It will not be as nimble nor will it go through a 4 foot gate but will gain a ground clearance and bigger tires. The little BX tires and short wheel base will beat you on rough ground and it worse with loader full. The bigger loader will move more and lift heavier things. Don't know about a belly mower but it will sure pull any type of 3 point mower you want (in the right sizes of course).
/ Recommended Tractor for 4.5 acres #14
Weight = work for ground engaging tasks. The lighter the machine, the harder it is to get an implement into the ground or move things.
I would not go smaller than a Kubota B series (or JD 2 series) or equivalent. I am also not a fan of flail mowers...300 moving parts vs 50 on a rotary cutter. Just more to break. Personal preference here.
How much dirt needs to be moved?
/ Recommended Tractor for 4.5 acres #15
They probably are cheaper. If you have good dealers around for these other brands (by that I mean they have been in business over 10 years selling the same brand (not 5 different brands) and have a good reputation then I see no reason not to consider them. Demo, see what you think.
Personally I am right with ya, but dealer and parts support are more important to me than country of origin.
I would also personally recommend you stay away from rebranded machines. Bobcat, RK, Bad boy...the list goes on. Just get the original mfg version (LS, TYM, etc).
/ Recommended Tractor for 4.5 acres #16
Thanks!
You didnt say what hobby you will be partaking in on the farm? I hope its not just mowing grass! I am asking as things like hay bales , tilling, plowing could have an impact on choice.
/ Recommended Tractor for 4.5 acres #17
VIDEOS FOR YOU:
/ Recommended Tractor for 4.5 acres #18
Since you asked, my short list would be... in order of preference, Yanmar SA425 or SA324, Kubota, Massey Ferguson. Others will say it is all about the dealer, I would say it is all about the company that makes it. Now, that said, there are a lot of other great tractors out there. As far as BX vs B, night and day difference in capability due to weight, ground clearance, lift etc.
You could sufficiently maintain your 5 acres on the BX and I don't know the price differential without looking but I would pay at least another $4k for the B.
You can get a Yanmar SA425 for $20k it will outlift your B or your BX or your 1025R. It will be made by Yanmar and it will come with a 10yr warranty (Pwr train). It will also out lift the JD 2025r if that matters to you. Yanmar loads all of their tires.
/ Recommended Tractor for 4.5 acres #19
Y'all need to remember that Kubota now has a large manufacturing plant and its Western USA parts depot in Lenaxa, Kansas. The OP is in Kansas.
/ Recommended Tractor for 4.5 acres #20
Y'all need to remember that Kubota now has a manufacturing plant and its West Coast parts depot in Lenaxa, Kansas. The OP is in Kansas.
I live 30 minutes from the Honda plant in Marysville Ohio and I don't drive a Honda. That would not be a factor for me at all. Even the parts depot, my expectation would be that a reputable dealer would get parts regardless of where they are manufactured. I do, however, like Kubota but I think the OP will find that he may run into inventory issues with Kubota right now. I did.
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
