Hydraulic Side Shift On 3PH
/ Hydraulic Side Shift On 3PH #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
This is being used to hillside cultivate row crops. The 3PH is unique in its location between the front and rear wheels of the tractor as seen in this video:
/ Hydraulic Side Shift On 3PH #2
The cultivator bar is where it should be as it is the easiest to see and make quick adjustments. Many belly bars on tractors through the years
Yes and the Allis Chalmers Model G is a good example. The Fendt in the video looks like it utilizes a conventional 3PH just behind the front wheels for various attachments.
I can see some advantages of a cylinder operating at least one of the 3PH lower links particularly if the valve has a float option. Even the Quik-Hitch folks could make use of it for alignment when mounting an attachment.
John Deere 7000 Planter (A63109)
John Deere 7000...
2017 Skyjack SJ16 500lb. Manlift (A61567)
2017 Skyjack SJ16...
2018 John Deere Z950M Zero Turn (A63116)
2018 John Deere...
207271 (A52708)
207271 (A52708)
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
