How agriculture works thread
/ How agriculture works thread #501
Crop sprayer on US81 in Nebraska. It's that time of year up here..
/ How agriculture works thread #503
Doing a powerful lot of crop dusting here as well. I took a gander at the beans across the road and they don't look all that healthy, something is in them. Same with the corn. Haven't seen them dust fields here in a long time here. I cringe when I think about chemical cost too. I usually spray my hayfields with a foiliar inoculant but I'm not this year because the cost per gallon tripled. Just applying 46 sparingly. The big sprayer is staying in the barn. I did spray my potatoes and beans in the garden with Sevin last week, not because I observed any damage, just want to be prepared for leaf hoppers. Use a hand sprayer for that.
/ How agriculture works thread #505
I didn't think that had changed the shakers/walkers much as well.
Yep - they are gone. Out of the rotor and out the back unless it hits the chopper first.
/ How agriculture works thread #506
Hummmmm are you sure? This axial flow combine has a shaker to clean and move the grain back, like they've had for 100 plus years.
/ How agriculture works thread #508
I had not looked at the Fendt. The CIH Axial Flow just uses the rotor and then one cross rotor for separation and the straw goes out the back. A lot of ranchers do not like the rotaries as they grind the straw much more making it tougher to bale and handle. My brother says they remind him of the old corn shellers but they are a little more sophisticated with higher speeds and the concaves they surround the rotor with.
For anyone who'd care to see how combines can separate grain from the stocks and chaff, here is a really nice video of that. This is how combines have been made since around the turn of the century.
This shows a standard position cylinder which it the large paddle like part that knocks grains off the stock but today most manufacturers are "axial flow" and they rotated the cylinder and added a second one. My description overly simplified but you get the idea in this video.
/ How agriculture works thread #512
Here is a transverse rotor Gleaner video that shows the accelerator rolls and how they assist in the separation. It also mentions the sidehill capability versus an axial flow rotor. Not that I am a Gleaner fan but they have their advantages - one being that they are about 10,000#s lighter than most others with their capacity which in today's world of soil compaction issues is huge. Also no straw walkers.
/ How agriculture works thread #513
Here is a diagram of a CIH 9250 - no walkers or pans - just the rotor and the transverse rotor for final knockout and chopping with sieves down below.
/ How agriculture works thread #514
No Gleaners around here, some CNH however. Couple years ago I helped remove the rotor on one. Difficult job as it's angled.
/ How agriculture works thread #515
Angled and heavy. How did you do it? I have heard of opening up the concaves and placing some wood around the lower part and closing the concave to support the rotor while you take it loose and then using a loader, forklift, liftall or whatever drag it out of the machine. A crane would be a lot handier but most people do not have them handy for that size and that high.
/ How agriculture works thread #516
I find it interesting that the new Deere X9 uses two rotors but it looks to me like a good share of the threshing is done in the feederhouse more conventional style and then the rotors are more for the separation of the grain from the straw. Definitely a lot of moving parts on the new Deere with all those grain catch pans and related augurs up underneath the feederhouse.
I love the concept of the accelerator rolls but I need someone who knows and will tell me that they got their problems worked out.
/ How agriculture works thread #517
So, after all that, are Rotary Combines more capable on hill ground or not? ;)
Yes they are. Lets say normal cylinder combine in 1960 could do a level field with 1%* chaff and minimal grain loss. Put it on a hillside and gain loss goes up to 6%* plus the chaff continuation up to 5% and the price for your grain will of course be downgraded at the elevator. These new axialflow machines will do much better on that same hillside.
*not real numbers
There is a shaker pan to move the rain back at the bottom.
/ How agriculture works thread #520
Ever see someone in a low slung sports car drive under one?
Its pretty common here to see it.
I've seen them come in over the apple orchard I was working in, and as he was going up, lift the tail of the plane to clear the roof of the cold storage building.
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
2012 International Prostar (A61307)
2012 International...
2015 Dodge Grand Caravan Van (A61569)
2015 Dodge Grand...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
1629 (A57192)
1629 (A57192)
2018 FORD F-150 (A60736)
2018 FORD F-150...
