Starting a new adventure with a oliver 60 row crop.
   / Starting a new adventure with a oliver 60 row crop. #11
nice find...will you be using it on level ground?
It is not going to worked it is going to get restored and taken to tractor shows.
   / Starting a new adventure with a oliver 60 row crop. #13
way to go
   / Starting a new adventure with a oliver 60 row crop. #14
First thing to address when overheating is the fan belt. Make sure the fan really "roars" when at WOT. Try turning the engine over by hand, with the fan. The belt should only slip with some effort.
Second thing is put a trouble light in by the fan blades. Do this inside or dim daylight outside. Then go look thru the grill, remove the grill if necessary. If you can't see the trouble light, that could be the problem. Blow out the fins with air or a strong stream of water until you CAN see light thru the core.
These are 2 cheap and easy things to do before you start with flushing, head gaskets, etc.
Fan belt was to loose had to get a new belt did that on Sunday cooling is doing better.
The is radar looks to be rebuild already.
   / Starting a new adventure with a oliver 60 row crop. #16
had a MF TO35 for many years. the radiator was heavy duty but not providing adequate cooling like yours. you might look at it being rodded out bu a shop if it is heavy duty construction. but you don't see much of that these days, all about replacement with plastic. good luck
Need help.
Does the fuel line look right ?
It will start and run for a couple of minutes then die like it is running out of fuel.
Can't find out why it is dieing.
   / Starting a new adventure with a oliver 60 row crop. #18
Possible that the fuel supply valve above the sediment glass is pinched too much.
   / Starting a new adventure with a oliver 60 row crop. #19
I can't say I have experience restoring an Oliver tractor, now an Oliver plow is another story!
   / Starting a new adventure with a oliver 60 row crop. #20
Bet there is debris in the tank. Someone added the inline filter to help. Blow a puff of air back to tank but eventually will want to pull , clean and coat tank.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2012 CATERPILLAR 308E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2013 Ford F-450 (A50323)
2013 Ford F-450...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
