Front-End Loader Ford 1100 4WD
/ Ford 1100 4WD #1
rvkitch
parker colorado
Ford 1100
Hello All,
Brand new to the blog world, so thanks in advance. Just bought a Ford 1100 4WD yesterday and wanting to mount a front end loader on it but basically this tractor has no frame under it except for some angle iron that sits basically all towards the front of the tractor. There are 4 large threaded bolt holes in the clutch housing casing area on each side of the tractor but I'm not sure if I dare mount the loader uprights to these or not. Don't want to break anything. I have found a few photos but none that really show how the loader is mounted. I am a welder and can fabricate all the brackets but still need something to mount them to. Any help would be greatly appreciated. Thanks Again.
rvkitch
/ Ford 1100 4WD #2
Hello & welcome to TBN.
The FEL on my 1100 mount to brackets & braces front, center, and also back to the rear axle. Maybe these photos will give you some ideas.
Let me know if you'd like me to send you a PDF of the Ford 768 FEL owner's manual/installation guide. Wouldn't be until at least Monday, though. I can get you better pictures if that would help.
/ Ford 1100 4WD
WOW, Thanks a Million Wyeguy. Those are the best photos I've seen yet. Could I bother you to take a shot of the steel bracing heading back to the rear axle and how it's mounted to the axle? Also, a PDF of the 768 FEL would be amazing and appreciated. I hope maybe in the future that I can help someone out this much.
Thanks Again
/ Ford 1100 4WD #4
drilled and tapped boss/holes inthe bellhousing is a common attachment point for laoders and other equipment for tractors.
/ Ford 1100 4WD #5
Rear brace us bolted to the rear axle bell housing as Sound guy said. Very difficult to get a good pic, but it's shown in the first photo.
The second photo of the middle brace has a bad shadow that make the bolts hard to see.
The third photo shows some of the front brace. Sorry, I'm obviously not a great photographer.
I'll attach the installation manual in the next post. Its a BIG file....
/ Ford 1100 4WD #6
I'll have to try to send the PDF later this evening from home. Its not going to work from my phone.
/ Ford 1100 4WD #7
The forum doesn't allow a file size bigger than 1M. Sorry, I didn't know this. If you want me to send the FEL attachment manual via personal e-mail, send me your e-mail address via personal message. Unless you have another idea...
/ Ford 1100 4WD #9
hi i am building a front loader for my 1980 ford 1100 4x4 i have been reading and looking at the pictures posted, they have been very helpful thank you
would you be willing to post a few pictures of where the lines tie into the tractor , i am finding it hard to find the information on if i need to add valve block or if it has a spot where you can tie into hydraulics , any info would be appreciated i have only owned the tractor for a couple months it a very cool little tractor but I dont know much about
the hydraulics
/ Ford 1100 4WD #10
I haven't been on here forever but if you still want help with this, let me know.
/ Ford 1100 4WD #11
/ Ford 1100 4WD #12
I hate to drag this post back from its deep freeze but I have this tractor setup with the fel. If you still have the manual I would love to have a copy!
mracer454@yahoo.com
Tractor Mike, I have a manual for the 768 Loader. I could copy it and email it if no one else can help you. My loader was on a 1210, which I can also take pictures of the lines to help you out if needed. I've started removing the brackets and lines moving it to a different tractor. My 1210 is worn out.
Let me know if I can help.
/ Ford 1100 4WD #13
That would be great if you could. No hurry at all, when you have time. I have the 768 loader on my 1100 Ford. No issues with it just like to have the docs on hand in case I need them… hopefully I don’t!
/ Ford 1100 4WD #14
What a great thread this is, I have to say this is one of the most friendly and helpful forums out here on the farm. Great stuff and I would like to thank those in the know for helping out those looking to educate themselves. Without your knowledge our row would be a much longer hoe.
Thank Ya'll.
Dutch.
/ Ford 1100 4WD #15
Also if anyone is still following this thread, I would also love to get my hands of a copy of the manual for the ford 768 loader as I am an owner of an ford 1100 and am beginning the first steps in fabricating a loader for this awesome tight space little mule, and any info would greatly help and be greatly appreciated, especially the attachment structure detail of the carriage for this loader.
Thank you all for a great resource.
Dutch.
/ Ford 1100 4WD #16
Dutch.
Dutch, I am interested in the progress and any photo's you you might have on the plans and or fabrication of a loader for these little guys :). Thanks Rick
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
John Deere 6140R Tractor (A64047)
John Deere 6140R...
Poly Machine & Parts (A64047)
Poly Machine &...
