TC40 glow plug issue
/ TC40 glow plug issue #1
nyone
Elite Member
Ford 851
Just got this tractor with 3,000hrs. The glow plug indicator light is lit all the time unless I disconnect the timer control box under the dash. Does anyone have a wire diagram or any helpful info about how to repair this?
Turn signals and flashers also dont work. Although the lamps do light when I jump power into the relay sockets.
/ TC40 glow plug issue #2
I hope theses will help with your issue.
  • Elec Schematics.pdf
  • Glow Plugs.pdf
  • Turn Signals.pdf
/ TC40 glow plug issue #3
My tc33 started doing the same thing a few years ago. I replaced the glow plug timer relay to fix the problem.
Thank you. I will check the schmetatics.
Thanks Thclimber I narrowed the issue down to the original NGK glow plug timer.
You dont have a digital copy of the service or owners manual do you?
/ TC40 glow plug issue #6
I had to replace my glow plug timer last fall and, in my case, a similar (much cheaper) P/N that supposedly cross-referenced did not perform properly. I tried to go with that at first, but ended up buying the expensive dealer part and that worked out. That's just my experience. I described this in detail here:
/ TC40 glow plug issue #7
When I did mine I think I used a Kubota relay I got off of eBay. Works perfectly and was much cheaper than the New Holland part from the dealer.
Got my $15 ebay timer and plugged it in...problem solved..at least that one. No clue if the glow plugs actualy work yet.
