Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #6,321
Sorry, but i dont see how that tire would eliminate chains in ice.
Oh there's no substitute for chains 👍, my traction comments were not very clear, I was talking about not noticing a difference in the dirt.
I think that in the snow alone this tread is better than a R1 ag. but there's only one answer for ice imho, and that's the "mechanical" connection that chains and to a lesser extent, studs can provide.
/ Pictures of your snow weapons #6,322
Surprisingly for a 5' wide Chinese made blower this things been pretty durable for about 20 hrs in the UP, always starts still on original shear pins, blows snow 30' but it is really slow going anything over a foot. Vbar tire chains and extra weight in the rear make a huge difference.
/ Pictures of your snow weapons #6,323
Haven't got much snow yet this year but clearing off my 1/4 mile long blacktop lane gets the Sun on it and really accelerates melting. The poly edge is new for this year. Chatters on the dry pavement but behaves nicely once loaded. Still learning with it.
The Rhino 5006 handles ~%80 of the snow work anymore. Super handy for those common 'nuisance' snows. Use the offset boom throughout the season to keep the lane from magically 'narrowing' like it always does somehow ;<)
nice setup dadohead....looking for a poly edge myself....where did you find a good place to get one? I have a rubber edge now on my 60" plow but its not wearing good...that chatters on dry pavement too.
/ Pictures of your snow weapons #6,326
Cat Fever
Great property and vistas you have are amazing, and glad to see the "last barn" is complete!
I think "Big Barn" here has some competition on the biggest barn :)
/ Pictures of your snow weapons #6,327
Nice setup - Do you have a link or info on these 5' powered blowers, and rough cost?
/ Pictures of your snow weapons #6,328
It's a mossimo I believe the price has went up significantly like everything else since last year when I got it. I did have to modify the supplied mounting plate and It had a plastic cover over the top but it broke off I don't see a need for it anyway as it hinders access to the fuel cap and dipstick unless you have tiny hands.
/ Pictures of your snow weapons #6,330
Let me put it this way if it was 3k
back then I'd probably spend more and get a more reputable brand. The auger frame is pretty heavy gauge steel, the motor is good but a little underpowered, the electric powered chute is a great feature. The only problems I've had with it so far were cosmetic and ergonomic issues. Electric start is nice and I wired it into my 2 prong trickle charger harness off the atv battery. I drilled and
tapped in a few grease fittings where I thought they should have some. Also The instructions they send you are garbage. Out of habit I drained the oil and put a synthetic blend in it when it was new. I also was going to change the gear box with synthetic lube but it was packed full with grease. I think if it's going to have a major failure somewhere the aluminum gear box will be it. And if I stored it outside I'd probably repair and remount the plastic cover but it isn't. For a little over 2k it was worth it for me anyway especially if it lasts a couple winters. Which would be the cost of hiring out to keep my cabin drive plowed for a few years. Plus I actually enjoy plowing/blowing snow.
/ Pictures of your snow weapons #6,331
/ Pictures of your snow weapons #6,332
Snowblower on the front...hyd. Driven gear pump
/ Pictures of your snow weapons #6,334
I converted a rear mount, PTO driven, to a front mount hyd motor driven,...using a PTO pump.
...converted a 20 gallon, Well water pressure tank ( yes I removed the rubber bladder) to a hydraulic tank.
works great!
/ Pictures of your snow weapons #6,335
Nice work! I really like your valve/camlock setup!
You're going to love the loader mount blower! :)
/ Pictures of your snow weapons #6,336
Interesting. It looks a little bit underweight, but I bet an enterprising person (like most of us...) could find a way to mount that to a front end loader...
It is much too light and lacks power.
/ Pictures of your snow weapons #6,337
I wish my 6' loader mounted blower was lighter so that it would float a little better.
It looks like a Prince pump (or very similar). I use a 21gpm Prince pump and it is plenty of flow. I don't have the hydraulic motor sizes handy, but with 21gpm I'd swap them out for larger motors to gain torque and slow auger and the fan speed down a bit.
I used a 38hp tractor for years and it was fine. (Although my current 66hp tractor with cab sure is nice in the winter! ;) )
/ Pictures of your snow weapons #6,338
I'm getting smarter with age, send my daughter out and I'll stay in where it's warm
/ Pictures of your snow weapons #6,339
That has to be the most inefficient snow weapon of all time. The tiniest blade combine with an extremely high price tag. For years I rode a $75 mtd that had a manual blade 3x that size, and with chains it really ripped.
/ Pictures of your snow weapons #6,340
Electro hydraulic plow, heated cab, and a dump bed with about 500-lbs of sand in it. it has never slipped. I have a set of chains riding around in the tool bosx that I put on when I bought them to make sure they cleared, and put back in the bag.
I started looking for a UTV to plow with, and saw one of these in a parking lot, and realized, that something with a closed cab, and a heater would be far more comfortable to plow in than a side by side.
2017 Ram 5500 Bucket Truck (A61307)
2017 Ram 5500...
Kubota Snow plow with subframe
Kubota Snow plow...
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
2006 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2006 JLG 600S...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
