Turn up the fuel in a 5211.
   / Turn up the fuel in a 5211. #1
ZetorSteve
Missouri
Zetor 5211
Looking to get a bit more it of my 5211. I read on zetorworld awhile ago about how to do this but that site is still currently down. The 4x4 round baler really drags the tractor down with a full chamber. I actually stalled the engine near full chamber when I sucked in a big was of Johnson grass.
The tractor never blows any smoke, even under heavy load. Even when it was bogged down before the stall, no smoke. Was hoping to get a few more ponys to spin the baler.
   / Turn up the fuel in a 5211. #2
Yes, i swapped Zetorworld.com for a pair of mudguards for my 3011, with the guy from zetorforum.de because i dont have the means to transplant 20 years of forum archive to a new forum platform because the X-forum script doesnt run anymore on the latest Apache servers.
Its a long time ago, but i think it was the upper screw behind the rear cover. Undo the locknut with a 13mm wrench and turn the rod with a flat screwdriver.
Its good to write down which screw you adjusted, and how many turns: because a 3 cylinder governor is slightly different to a 7745 governor, i loosened the governor spring so it didnt get above 1200rpm. Then put it back and took the upper screw, turned that a stroke, snd that really woke her up. Slight gray smoke, but it pulled a rented 10m3 tanker to speed over the distance it used to pull the 6m3 tanker to speed.
What i did as well, was swapping the fine mazed 3 cylinder radiator for a coarse 4 cylinder radiator we kept on the hay loft. It allways ran hot before in the work we did with it, but the coarse radiator and a stroke on the pump made it meet the expectations set by its predecessor, a 4712.
   / Turn up the fuel in a 5211. #3
Hello Renze, is there a coarse radiator for replacement in a 5211,
my rad looks to be a fine mazed original and repaired many times,
so if replacing it i would rather have the coarse.
   / Turn up the fuel in a 5211. #4
Radiators are the same, just the core is different.
207277 (A52708)
207277 (A52708)
Golf cart (A56859)
Golf cart (A56859)
1994 Blue Bird Command Center Bus (A55973)
1994 Blue Bird...
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
2013 HINO 338 26FT BOX TRUCK (A59575)
2013 HINO 338 26FT...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
