What size and thickness plastic pipe for 4x4 post?
   / What size and thickness plastic pipe for 4x4 post? #1
fishpick
The part of NY with high taxes
L4760 & BX24
I want to set a section of PVC or other type pipe in the ground and then be able to place a 4x4 post into the pipe. It does not to be a perfectly tight fit. I can shim it. But the point it to allow me to remove the 4x4 as needed.
This is not structural- it’s for posts in a shooting range.
Any idea what type of pipe / thickness? Fits a 4x4 nicely?
   / What size and thickness plastic pipe for 4x4 post? #2
I’d use schedule 40 4” PVC and just shave your post corners a little. It would take 5 minutes with a circular saw or just use a sharp axe.
You can put PVC caps on the pipes when not in use to keep them clean and make them easier to find.
   / What size and thickness plastic pipe for 4x4 post? #3
Diagonal of a 3.5x3.5 square is slightly under 5 inches. Standard plastic pipe charts with ID, OD, wall thickness, and schedule are common online.
Personally, I'd just grab a tape measure or a 4x4 stub and go to a plumbing supplier.
   / What size and thickness plastic pipe for 4x4 post? #4
A^2 + B^2 = C^2
C = sqrt(3.5^2 + 3.5^2)
C = 4.95”
   / What size and thickness plastic pipe for 4x4 post? #5
A^2 + B^2 = C^2
C = 4.95”
Not a single word was written but this ageing D student understands it...It's got to be a first for me.
   / What size and thickness plastic pipe for 4x4 post? #7
Considering the cost of 4" or 5" schedule 40 PVC, I might consider schedule 35 vent pvc and set it in concrete so the actual strength doesn't matter. But remember the sizes are a little different. Schedule 35 fittings do not fit Schedule 40 pipe.
   / What size and thickness plastic pipe for 4x4 post? #8
The holes will get full of dirt and trash, jamming the post. I would go the other way. Short, solid posts, maybe pipe, with a lighter tube, pipe, or post to to slide over it or attach to hold the targets.
Bruce
   / What size and thickness plastic pipe for 4x4 post? #9
On my target range, i arranged a double row of rail road ties and buried them. left a 4” gap between rows. I can simply make my 2x4 shooting frames and simply place them inside gap.then i place a small x piece of scrap 2x4 at base and screw the upright posts to base. Extremely sturdy. I use the small base crosspiece to straighten the stands….gives me a bit of adjustment.
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
2025 40ft 2-Door Shipping Container (A55787)
2025 40ft 2-Door...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
18' 18" Corrugated Pipe (A53316)
18' 18" Corrugated...
New 4-12-16.5 Forerunner Skidloader Tires & Rims (A50775)
New 4-12-16.5...
