Oil & Fuel GC1715 Blowing hydraulic fluid
   / GC1715 Blowing hydraulic fluid #21
The most likely spot to get air in the suction side is the strainer/filter behind the left rear tire. There is an o ring on the tractor side of the housing that may not be installed correctly. It may not leak oil, but could allow air to enter. If you just did a fluid change, I would assume you removed it to clean the strainer. There are videos of it on YouTube.
No I didn't remove i took it out the last time I did service and it looked like new so this time I didn't remove it.
   / GC1715 Blowing hydraulic fluid #23
Unless the fluid is looking a little milky, I would doubt an air leak. Check the filler cap. They are poorly constructed for a $25 part.
Just curious, what hydro fluid are you using?
Drained fluid and changed the filter again put a new filter on it again this time put the filter on that matched the one I took off turns out it fits the GC2300 it is about a inch taller. That didn't help turn out I think it does it when I run on a hill on my property. Talked to mechanic at local dealer said he never heard of one doing that.
Did like this tractor a lot, now thinking about trading for a new one .
   / GC1715 Blowing hydraulic fluid #26
Did you try opening the vent hole on the filler cap? The pressure builds in the hydro housing, can blow out the sight gauge, and eject oil out the fill tube when going up hill.
Pushed a toothpick in hole at the side of cap and could see it from bottom of cap
   / GC1715 Blowing hydraulic fluid #29
Early version of the GCs also had a breather hose that seems to be missing on the GC1705/10. They never suffered from these issues. From what I know, the only vent for the transmission case now is the filler cap. It is poor quality.
   / GC1715 Blowing hydraulic fluid #30
There is about a 1/16 hole in cap/plug that directly connects to bottom side of plug for vent, if you can take something like a can of WD 40 or PB Blaster with a wand and blow product through hole, venting is not your problem....
IF you change filters and problem did not go away, filter is not your problem....
Only other way to change volume of hydraulic fluid if it is drawing air in some place and aerating fluid enough to change volume in HST drive and the only way extra volume can excape is through cap/vent ....
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
Informational Lot - Financing (A56435)
Informational Lot...
1345 (A57192)
1345 (A57192)
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
JOHN DEERE CT322 SKID STEER (A52707)
JOHN DEERE CT322...
2023 John Deere 333G for Parts (A57024)
2023 John Deere...
