Anyone ever "delete" the dpf on a tractor?
   / Anyone ever "delete" the dpf on a tractor? #51
Sure they do. Drive a mile in my shoes and see what its’ like to have your vehicle inspected in a routine roadside stop.
They don’t do that in the west.
   / Anyone ever "delete" the dpf on a tractor? #52
i guess you don't go in arizona utah or neveda, I have been stopped and searched at multiple checkpoints over the years.
   / Anyone ever "delete" the dpf on a tractor? #53
I lived in Arizona for 45 years. Never heard of such a thing. But I didn’t live in a metro area.
   / Anyone ever "delete" the dpf on a tractor? #54
Also, believe that California has/is making it illegal to operate pre-emissions commercial vehicles.
Seems to me that is a violation of interstate commerce clause. I can see not titling/licensing a vehicle in CA, but if I own/operate a federally legal commercial vehicle & have a load to pick up or drop off in CA, they shouldn't be able to prevent it. Unlikely the current (federal) Administration would push the issue, but it seems like a "no brainer" that the Supreme Court would strike that down. Maybe the supply chain & port backlogs would clear quicker if they simply let any trucker operate.
   / Anyone ever "delete" the dpf on a tractor? #55
If the factory warranty was expired I wouldn't hesitate if I was having problems and I would keep my mouth shut and no one would be the wiser, if you tell it some do-gooder will likely rat you out.
Prisons are full of those that talked too much.
   / Anyone ever "delete" the dpf on a tractor? #56
Maybe he doesn’t get out much?
   / Anyone ever "delete" the dpf on a tractor? #58
To the op who started the thread, yes you can do a "delete". The tractors concerned had the dpf deleted and the rest of the engine setting left standard. There have been zero problems as a result.
Re axelpops, post 54, As of this year or last year,it is illegal to operated a pre2010 emissions truck BASED in California, BUT there is a CUTOFF date for OUT OF STATE trucks as well. I don't know when that starts.
   / Anyone ever "delete" the dpf on a tractor? #59
He's a fed. They don't mess with feds.
Ahhh, that explains it.
Do you get a secret license plate code so the cops don’t light you up?
Case VAC Tractor (NOT RUNNING) (A50775)
Case VAC Tractor...
1999 Talbert T30W-50SA-HRG-1-T1 (A47477)
1999 Talbert...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
14179 (A55788)
14179 (A55788)
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
