Farmtrak 270 dtc
/ Farmtrak 270 dtc #1
tommyb2117
Farmtrak 270 dtc
Tractor stopped working overnight. Engine is not cranking and lights were not turning on. I have installed a new battery, lights are working but engine is not cranking. Have changed fuel filter and bleed air. Any suggestions on next steps would be greatly appreciated.
/ Farmtrak 270 dtc #2
Have you checked fuses? Also see if there is current getting to the starter. Not sure if your machine has safety switches, if it does then I would be checking them as well. These are some things to try and start the elimination process.
/ Farmtrak 270 dtc
I will try the fuzes next. I have looked through the manual but do not see anything on safety switches. I appreciate the recommendation
/ Farmtrak 270 dtc #4
What year is your tractor? From pictures I saw on the internet I'd be willing to bet it is new enough to have some safety switches. At least maybe a seat safety switch??
/ Farmtrak 270 dtc
Thank you both for your responses I greatly appreciate the help. I was able to find a loose connection going toward the starter. There was a fork terminal that was slipping away, I replaced it with a ring terminal to make sure it stays in place.
/ Farmtrak 270 dtc #6
Glad you got it figured out!! Thanks for letting us know what the problem was!!
