What is this lifting ?? tongs for ??
   / What is this lifting ?? tongs for ??
Well, the hooks would go the other way if you pulled them around the ring.
You caught me. I thought of that afterwards and was hoping nobody would notice. :) Still needs a spreader though to be a decent hog hanger.
gg
   / What is this lifting ?? tongs for ?? #54
Probably for I beam. All you'd have to do is put it on the beam and then put a large shackle on and it slides down and keeps it tight. I've got an old digger derrick truck for digging power pole holes and setting the poles. In fact, I have two of those trucks. I have some old things like that I found in the tool boxes.
   / What is this lifting ?? tongs for ?? #55
I don't know why I did not realize what that is. I was taught about that on my very first construction job right out of high school - never saw one but the boss kept talking about it. It is a sky hook. I was sent to fetch it a few times. Never found it though. It is supposed to be very useful.
   / What is this lifting ?? tongs for ?? #56
Found this in the woods. I can see that it is for lifting something like an I-Beam maybe. It looks like it has a specific purpose. It was near a high tension power line ???? Someone knows what it is, Thanks
gg
Looks like antique homemade iron log skidding tongs.
   / What is this lifting ?? tongs for ?? #57
I also think it was for drums or something similar:
Straight shanks, flat tips and no pivot will not work on logs.
You are absolutely right - a barrel or an I-beam, something with a lip. They are plenty rugged. Here is a better pic
So many have said that it was for logs I brought it out into the woods today and tried it on a couple log. Useless, as I suspected. Even using a 3 lb hammer to set the hooks they would not stay set or try to bite in. You would go berserk before you got any logs out trying to use them to pull wood.
gg
   / What is this lifting ?? tongs for ?? #59
Looking at that picture agree that it was used for some type of drums, rather than logs.
   / What is this lifting ?? tongs for ?? #60
Wow. Larger than I thought.
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2017 Ford Fusion S Sedan (A55853)
2017 Ford Fusion S...
John Deere 4510 (A53317)
John Deere 4510...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
