Lucas X-tra heavy duty grease sold out?
   / Lucas X-tra heavy duty grease sold out?
If you can find it, Mobil polyrex ep2 is also polyurea based and green and would be a very good substitute. I would have no qualms mixing these.
Hmmm…good to know.
Thanks. I am going crazy trying to find Lucas Green and the reservoirs on the balers are close to empty.
   / Lucas X-tra heavy duty grease sold out? #13
I use JD's Severe Duty PolyUrea Grease. Compare their technical product description with the Lucas and you may agree that it seems like the same grease. Even the same color. Std. JD tube is about $6.45 locally. Less for a case.
Luck,
rScotty
   / Lucas X-tra heavy duty grease sold out? #15
Lucas 10301 $8.69-local NAPA has 1!
Sister stores have 18 more at 4 locations.
Nothing else showing at warehouses.
Seems like I was selling it for 5-6 bucks when I retired 3 years ago.
Good Luck!
   / Lucas X-tra heavy duty grease sold out? #16
Luck,
rScotty
Is this the JD polyurea grease you are referring to?
   / Lucas X-tra heavy duty grease sold out? #17
I was curious and started searching for heavy duty poly urea grease online. It seems like most sites are listing poly urea grease as sold out or very expensive, no matter what brand.
   / Lucas X-tra heavy duty grease sold out? #19
WalMart completely sold out.
Yeah, all the auto stores, Home Depot and Walmart; all sold out of poly urea grease of any brand. The same online with most companies.
   / Lucas X-tra heavy duty grease sold out? #20
Another option is to switch over to calcium sulfonate based grease which is quickly taking the place of polyurea.
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2013 Nissan Pathfinder SUV (A50324)
2013 Nissan...
2025 LandHonor LHR-RF24 Ratchet Tie Down and Flatpack Tool Box (A49462)
2025 LandHonor...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
Set of Ag R4 Wheels and Tires (A52128)
Set of Ag R4...
Fork and Frame Skid Steer Attachment (A49462)
Fork and Frame...
