Lucas X-tra heavy duty grease sold out?
   / Lucas X-tra heavy duty grease sold out? #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Can’t get my Lucas green grease anywhere.
Anyone else seeing this where you live?
I need for my square baler and I don’t like mixing greases.
   / Lucas X-tra heavy duty grease sold out? #2
even grease @ Wal seems to be getting scarce. i ran across some Lucas Marine grease that i like, doesn't seem to separate & easier to work with (tractor & utility). but may not be up to your stds. anyway, what is the consensus on marine grease for agri applications? good luck locating, we're in the heart of hay season w/no rain in sight
I always bought it because it was available everywhere and is good quality.
I can’t find it anywhere now. I tried ordering from Summit racing (30 tubes $150) and they back ordered me.
None on Ebay unless you want to pay gouged prices.
Baler reservoirs are getting low. I don’t like mixing.
   / Lucas X-tra heavy duty grease sold out? #4
I have had a case of red and tacky on backorder through one of my mower parts distributors since the first part of May.
   / Lucas X-tra heavy duty grease sold out? #5
Lucas has been really struggling with keeping up with demand. Where I work is a distributor for them and their on time delivery rates on grease is particularly bad. I completely understand the hesitation to mix grease haydude.
   / Lucas X-tra heavy duty grease sold out? #6
It’s all the hoarders. People need to just relax and let the amazing supply system that the administration has in place work #putinsfault:rolleyes:
Local place had red and tacky when I was last in there and I got two tubes because my spares on the shelf were almost out…maybe I should grab a box or two if they have them.
   / Lucas X-tra heavy duty grease sold out? #7
I have been seeing the same thing with NGK spark plugs. Either not in stock or my supplier subs to Champion which I absolutely hate.
   / Lucas X-tra heavy duty grease sold out? #8
If you can find it, Mobil polyrex ep2 is also polyurea based and green and would be a very good substitute. I would have no qualms mixing these.
   / Lucas X-tra heavy duty grease sold out? #9
then you become a horder
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2014 TROXELL 130BBL VACUUM TRAILER (A50854)
2014 TROXELL...
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
