1998 Massey 231
/ 1998 Massey 231 #1
subdonnie
1998 Massey Ferguson 231
Tractor was pulling along and I heared a pop in Trans. Tractor quit moving. Clutch working good, PTO working but tractor quit pulling in any gear. Need advise.
/ 1998 Massey 231 #2
that have a differential lock?
if so and when engaged if you can move then you broke axle.
if no movement....gonna hurt I bet.
/ 1998 Massey 231
no differential lock. two wheel drive
/ 1998 Massey 231 #4
/ 1998 Massey 231 #5
/ 1998 Massey 231 #8
suppose you could lift rear while in gear spin one tire. if other don't spin opposite direction then its axle issue most likely. if that pinion were broke tire should still spin opposite if axles ok.
/ 1998 Massey 231 #9
Diff lock was an option. Not all tractors were equipped with it.
Did not know that. Mine has it. Wonder what other options mine may or may not have. My FEL bucket has two rows of square holes. Assume this was for a bolt on edge of sorts. It would need to be about 10” deep to bolt an edge on though.
/ 1998 Massey 231 #10
The 231 came equipped with differential lock.
/ 1998 Massey 231 #11
If you have ipto you have to pull top cover to replace coupler do not have to split it they usually spin out the splines changed lots of them on four wheel drive units
On the 230 model also saw a lot of ring gears break if it has wet brakes has bigger ring gear and pinion
/ 1998 Massey 231 #12
Start with the easy things first. Is the driveshaft still attached? Does it spin when you put it in gear?
6053 (A61165)
6053 (A61165)
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
2014 F-150 STX (A56438)
2014 F-150 STX...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2018 Ford F-150...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63118)
Midwestern...
